Bunch of kids in Skylines getting defected last night at Windy Point. Green 32, Green S13, Black 33 and a Black 32. Watched on while I ate dinner :)
They actually looked like kids. And you're so awesome for doing skids down the bottom.
No wonder the car scene is shit with idiots like these.
let me guess, sound like they straight off nissansilvia...
never forget the night i pulled in there in my gtr for 5 min, heaps of 12 yr old lookn kids in 32 gtst's and 1 in a silver s15, kid in the s15 shuffles over to me (literally)
and asks wat stereo i have in my car lolz... i laughed and left...
cant say much about wat happened interms of the skids, but as for the cops being there with them, it was because they had someone reverse into the green 32, nd drove off after an argument. as for defecting them dont know about that. it was a few people that i know that were there. nd u sure the 33 nd 32 were black nd not burgundy?
The Green 32 had no front bar - there's no way the 2 cop cars would let that slide!
Most likely. They looked like 16 years old.
Steve aka Madaz in Mile End this afternoon round 3.
Dohmar on Main North Rd at about 4-4:15.......wash your car.
Not gonna wash it while its raining ;P But thx for the advice - Sun shall be clean GTR day
-D
sorry mate we was not getting defected guy came in to windys and hit my mates green R32 so we called the police
yeah mate we know the cops we are all chill with cops.. sorry but we are not hoons.. A girl Ex boyfriend came to windys and reversed into my mates green 32, and then he drove off so he called the police so next time get it right
Edited by MAD R33
cant say much about wat happened interms of the skids, but as for the cops being there with them, it was because they had someone after an argument. as for defecting them dont know about that. it was a few people that i know that were there. nd u sure the 33 nd 32 were black nd not burgundy?
yes michel is right thanks man for helping out...
Edited by MAD R33
    • Duh... to answer my own silly question, it's actually described in the FSM... ...400 pages away at the end of the manual, for RB25DE/DET signal descriptions, it cites the TPSwitch signal action, is dependent on the TPSensor value ~ this tends to infer the builtin POT voltage signal is the primary, and the switches are fallback/secondary should the POT fail/TPSensor signal lost (and switch alone with no TPSensor signal allows for base idle speed setting).... makes sense... they (TPS units) used to fail/wear the POT with time, they're not exactly built to last ~ having the switch as a redundancy gets around this...(or, it's less likely both signals would be lost as they're on different power rails)... and of course wrt RB26DETT, you have to electrically disconnect the IACV solenoid from the harness, to defeat idle air control...
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
