spotted a blue 34 GTT with bob jane wheels on a flat bed today off port road
looked clean
Spotted same Blue 34 on flat-bed truck, turning onto Marion road from side-street after 1pm. Also spotted Silver R33 GTS-t parked next to me at basketball tonight, SAU stick on back-right qtr panel
looked clean
all within a couple minutes were 2 33 gtsts on greenhill rd one was an s2 in silver other was a white one with some huge bodykit,
then a sexy blue stagea at the fullarton kensington roundaboat, then a white 33 with same huge kit plates R33T parked on grote st as always.
Apologies for multi-post, system said there was an error. Spotted Gunmetal grey R33 GTS-t on Brighton road this morning heading up cement hill approx. 8:30am
looked clean
That was me... It's GTR though hahaha not a GTT
Rims got flogged from a shipping company's yard so they put junk ass wheels on and sent it down to me...
They dumped it down on rocks so it's at the panel shop getting fixed now :thumbsup:
Then off to Knight Engines to get a FULL rebuild :cheers:
Sounds nice Brad...post some pics when you get it sorted!
Hey guys huge update!!!
My white r32 gtr that was stolen on the 8th of this month at 12:30am on cliff street has been spotted around the area even around the castle plaza area, pretty sure it has different plates on so please please keep a look out if you are anywhere near these area, the front bar has a chip in one of the N1 vents on the right hand side, has polished ssr sp1's on it dead give away not many around (look very similar to work meisters) also has a marky mark exhaust tech junBL muffler not a cannon on it. please contact SAPOL or if your not sure take a picture and sent it to me on 0401475561 thanks Sam
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
