Did you check the Power Sterring level at the Back. If not look in the boot and on the right hand side there should be a cover you can remove and you can see the bottle and top it up.
Thats for R32s tho, R33 might be different.
Also check the HICAS Fuse in the fuse box, some ppl take it out to make the car RWD.
Although a lot of ppl don't like the HICAS it is still noticable. When my light came on and I started to turn in car parks, I could feel the steering alittle heavier as if there was a loss of movment.
Top the rear power steering fluid up and it was back to normal.
https://www.sau.com.au/forums/topic/205828-hicas-light-gtr/#findComment-3642859
That's the ATTESSA reservoir. And 33s have electric HICAS (?)
If you've had a wheel alignment recently, did they align the front with the steering wheel straight, or did they straighten the steering wheel to the fronts wheels?
https://www.sau.com.au/forums/topic/205828-hicas-light-gtr/#findComment-3644894
Ageed. Rear HICAS reservoir??? There are sensors in ur steering column as you know. They read a fault if you need to hold your wheel at 20 odd deg off centre either side for a long period and you go over 70-80 kph? Check ur wheel alignment.
https://www.sau.com.au/forums/topic/205828-hicas-light-gtr/#findComment-3650051
I have an after market Momo steering wheel and appear the same HICAS problem as the above. I've recently done wheel alignment so this shouldn't be an issue - however my steering wheel is sometimes off the center (sometimes better and sometimes worse). What can cause this problem?
https://www.sau.com.au/forums/topic/205828-hicas-light-gtr/#findComment-3655148
    • That's a short. Find the short. It will be somewhere between that fuse and the headlight. Start by removing the plugs from the back of the headlight and dimmer switches, and measure resistance to earth. Supply side (power from the fuse) should have none. The other side should have resistance compatible with whatever globe(s) is there (which is relatively easy to say for a normal globe, perhaps not as easy to say for LEDs). Anyway, if you have very low resistance, you defo have a short. Then you just have to run the wiring like you're running the bowel of a dog (on the operating table) that has swallowed something it wasn't supposed to.
    • Hey guys, need help figuring out why my driver side (RH) fuse 15amp keeps blowing. The Driver Sides Headlamp is out, i replaced these a long time ago with LED ones that were working for 1-2 years. Now, the driver side light is out and i traced it back to a broken fuse. I replaced the 15 amp fuse in the engine bay and as soon as i flip the headlight on, it blows the new fuse. Any idea what's going on?
    • I found the same with Subaru’s.  I own and love the SG9 Forester, after that model 2008+, Subaru threw the ugly stick at all their line up and somehow managed to make them look worse with every succeeding year.  lol
    • It's something we all have to consider as time marches on. Also consider lifted rally MX5 conversion at that point.
    • I should be fine for a few more years, whilst I do have arthritis I also exercise and do mobility training every day to keep as fit and healthy as I can, military life, which is the actual cause of most of my joint issues, has set daily regimes, which I weirdly enjoy I also train alot smarter now, not really focusing on lots strength or puffy muscles, I'm more focused on maintaining what I have for my future older self, I actually train as much mobility now as I do exercising Check out this "simple" drill I have been doing daily prior to training now for a while now, this has worked wonders in my all round mobility
