ardie Posted February 13, 2008 Share Posted February 13, 2008 (edited) Ok so I was working on the car, taking it back to stock for sale late last night/early morning and finished up and went to bed. When I went back out there this morning to look at it in the daylight I realised that I had used the block banjo from a spare water feed line as the oil feed banjo on the turbo if that makes sense. Looking at the two side by side, their dimensions are very similar with the water banjo being longer. They both run the same threads obviously, so this begs the question, do you think Ill be able to get away with leaving it in there? Only reason is I find it really hard to get time to work on it given work commitments and others but at the same time I don’t want to sell the car as a lemon Cheers Ryan Edited February 13, 2008 by ardie Link to comment https://www.sau.com.au/forums/topic/205871-will-water-feed-banjo-work-as-oil-feed-banjo/ Share on other sites More sharing options...
ardie Posted February 13, 2008 Author Share Posted February 13, 2008 nobody? Link to comment https://www.sau.com.au/forums/topic/205871-will-water-feed-banjo-work-as-oil-feed-banjo/#findComment-3644580 Share on other sites More sharing options...
Beer Baron Posted February 13, 2008 Share Posted February 13, 2008 so you used a slightly longer banjo bolt? the only thing I can think of sometimes there is a restrictor built into the bajo bolt and a water feed will most likely be flowing more than an oil feed. providing the orrifice inside the bajo bolts are the same (could be hard to check for certain) and you had it seated down on the washers properly it 'should' be ok. but I honestly think you'll feel better once you swap it. turbo oil feed is a pretty crucial thing to ensure long happy turbo life. too much, or too little oil and you have problems. and if it leaks even worse as it's under some decent pressure, and hot oil, onto hot manifold = fire. Link to comment https://www.sau.com.au/forums/topic/205871-will-water-feed-banjo-work-as-oil-feed-banjo/#findComment-3644724 Share on other sites More sharing options...
stolen_s15 Posted February 14, 2008 Share Posted February 14, 2008 Ryan I just put a hiflow on my car last week and I noticed that the oil and watre bajnjo's were quite different. I cant remember exactly what the differences were but I do remember thinking they were not interchangeable. Sorry for being a bit vague, lol. Link to comment https://www.sau.com.au/forums/topic/205871-will-water-feed-banjo-work-as-oil-feed-banjo/#findComment-3645910 Share on other sites More sharing options...
ardie Posted February 14, 2008 Author Share Posted February 14, 2008 ok so im trying to put in the oil banjo back in atm and it just doesnt seem to have the length in the thread for some reason?It will thread in for a thist or two and then stops, it almost feels like its the wrong thread, and then when i sit the two next to one another the threads seem no to match up which has me thinking that the one that I thought was the actual oil feed banjo may not infact be it So I think I have gotten the bolts mixed up. Bothe the bolts are more or less the same when I sit them next to one another, the one that I think is the "water" actually has a slightly smaller internal diameter, with the only real difference being the length of the thread Link to comment https://www.sau.com.au/forums/topic/205871-will-water-feed-banjo-work-as-oil-feed-banjo/#findComment-3646654 Share on other sites More sharing options...
SirRacer Posted February 14, 2008 Share Posted February 14, 2008 I dont really know dude, but ive got 2 sitting here in front of me (banjo bolts i presume your talking about) and they are completely different width and length wise. If you mean the hose tails (the piece the banjo bolt goes into) they are slightly different size depending on what they have come from. What turbo is really teh question. The garrett gt series doesnt use much oil. I went with -4 line for the bling factor. Link to comment https://www.sau.com.au/forums/topic/205871-will-water-feed-banjo-work-as-oil-feed-banjo/#findComment-3646661 Share on other sites More sharing options...
ardie Posted February 14, 2008 Author Share Posted February 14, 2008 (edited) Ok so to clarify, its a stocky as Im taking the car back to stock. And the banjo bolts I think I have mixed up are the oil feed that screws into the turbo, and the water return banjo that screws into the block If anybody could tell me what sizes they are, that woudl be awesome Cheers Edited February 14, 2008 by ardie Link to comment https://www.sau.com.au/forums/topic/205871-will-water-feed-banjo-work-as-oil-feed-banjo/#findComment-3646666 Share on other sites More sharing options...
