  • Replies 144
"so my number plate - VSP33C - vspec on a r33 makes me lame too?"
Dude that plate is good as... The only ones that shoudl be bagged are the one's that have been copied 20 different ways saying the same thing over and over... i.e. NV plates, DVS/8 plates... there is so good plates getting round that some people bag, i think its jus a bit of jealousy some of the time... and unless we peoples have a personalised plate themselves then don't bag anyone anyway, cos ya can't get any lamer than a stock plate really?
Come to think of it the lamest plate i have ever seen which will probs make you all laugh was "DRIFT" on a Toyota land cruiser prado?? WTF... if that thing tried to drift i wouldn't want to be withint 8 lanes of either side of the thing, would look like a ship in high sea's aswell.
Originally posted by riggaP
OIMLOW on a civic. It was pretty low, you stepped on the front bar when you walked past.
as in O IM LOW ? :confused:
or okka speak? 'gday mate, oim christian!' :O
i thought custom plates gave ya an extra 50rwkw..........only reason i got my ones :O
And for the record i was the first one with them. I have had them for 7 years!!! I have see 2 crappy WRX's with similar plates in syd now! I knew I should have got allll of them. hahahahaha
Originally posted by a5h
i saw "ST EYE" on a WRX thought it was pretty clever yet lame....
that's pretty cool...if it was actually an STi :(
hey Meggala...i love the CEFFY plate!! :D
it's definately not lame!
Originally posted by Duncan
BMW have been making made GTRs for 25 years too.
2 funny ones I can think of:
HGE1 on a car with a stock exhaust :bahaha:
and anything with NOS in the numberplate.  F&F wankers!
Originally posted by KamikazeR33
NOS-25T comes to mind :shake:
..... waits for a reply :D
:werd: and :werd:
I haven't gotten a personalised plate for my GTR yet because I'm stuck to think of a non-wanky plate for this one... I don't want another wanky plate :D
Originally posted by CerealKiller
F355 (F355 is a Ferrari for those that don't know) on a ute
err, 355 is an engine capacity, he prolly stroked his 308, if it was a holden. and his name could have been frank. dont judge so harse :)
as for the others, yes... lame
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
