Series 2 Xanavi Climate Control To Standard Conversion
DaveB
 Share
  • 8 months later...
It's a *lot* of soldering... or you can buy the conversion harness off Yahoo Jap. (ie. via import monster) and it's plug-and-play. I can at least verify that the harness works, though it's a bit of messing around to sort out illumination (there are two wires which are not part of the loom which you have to hook up separately).
  • 5 months later...
Hi all :)
I have issue with unit that turns on and off and finally asking for program cd. Is there any way to keep old xanavi in place repaired or I must swap with previous cc unit??
Some ppl said there is bad connection tho I don't have time to check it
Anyway appreciate for this infos very usefully
  • 3 weeks later...
I'm having the same or at least a very similar issue with mine, an error message fills the screen asking for program CD and wont let me do anything else, but the buttons and temp knob still work. I'm probably going to do the conversion soon, but if there's a fix i'd love that, i like the xanavi when its working haha
  • 3 weeks later...
  • 1 month later...
Hello guys
I know you have discussed this here,but i am just looking for a little clarity on the subject.
I have just recieved my 1998 S2 Stagea here in Canada and it also has the xnavi thing,and of course it does not work.My unit only shows the Nissan on the screen and nothing else.The temp functions seem to work but i see nothing on the screen.
I want to ask my buyer in japan to help me get some of the required parts to retrofit this with something a little more standard.
So I think I need the standard climate control ,surround,and radio brackets,where i am a little confused is the harness or adapter harness,this is something that someone makes in japan?
I looked through 64 pages of yahoo auctions last night under stagea ,but could not find anything(there were more pages but there is a limit before i get frustrated)
Since there are
no Stageas here in Montreal Canada ,i dont have anything I can compare with,so im hoping you guys can help.
So here s thanks in advance
Paulo
Any pointers would be welcome and if you have a link to what i need to get this done,that would be wonderfull.
Hi Paulo
Personally I kept my Xanavi screen and installed an intergrated GPS into it https://www.gpscity.ca/compare/gvn53 through the AV input in the rear, that way I retained the OEM look but had local GPS & aircon functionability on the screen. however if you want to do it the other way...
This looks like the harness You need http://auctions.search.yahoo.co.jp/search?ei=UTF-8&p=%E3%82%B9%E3%83%86%E3%83%BC%E3%82%B8%E3%82%A2++%E3%83%8F%E3%83%BC%E3%83%8D%E3%82%B9+%E3%82%A8%E3%82%A2%E3%82%B3%E3%83%B3&oq=&n=100&auccat=0&slider=0&tab_ex=commerce&mode=1
also the brackets http://page7.auctions.yahoo.co.jp/jp/auction/g131820786
and the AC head unit: http://page6.auctions.yahoo.co.jp/jp/auction/f132779952
there are lots of brokers out there happy to help you with the purchases (if you are happy to pay their fees)
Good luck !!
Hi Paulo
Good luck !!
Great Man,that really helps.
I would love to keep the screen,I would probably do the same thing you did and integrate a GPS receiver as well,what concerns me right now is the fact that the screen does seem to have a mind of its own.Now keep in mind I recieved the car yesterday and drove it home and to work this morning,I did not have any time to play with anything.
But this morning the screen sort of split in two and I had the climate control showing on one side of it.now I will ask a really stupid question...........................
When it was on the screen ,I saw a fan "button" and temp" buttons",now the stupid question............ Is this supposed to be a touch screen,??? I tried to touch or "push" the buttons and nothing hapened,by the time I was finished reversing out of the parking lot,that screen had disappeared again,and no amount of pushing on the various buttons could make it reappear once again.I did notice that turning the temp knob does change the heating functions,so at least that works.
Some of what I have read talks about crappy solder joints, is this a common problem on these units? has anyone sort of resoldered some of the boards and this has fixed the blanking issue?
I have an aircraft instrument repair shop,so I can spend some time trying to at least have the unit stay on, I also shoved a CD in the unit,but it didnt play anything,do I have to select something or will it start to play the CD directly when it works? (it did eject the CD though)
I hate having to tear stuff out,but this is "new" to me and we didnt get to many of these here in Canada,so I have to ask where the expertise is,and thats you guys!!
Any light shedding is again very appreciated.
Thanks
Paulo
Hi Paulo
Its been 7 years since i installed mine so its pretty vauge however when I get home in around 2 - 3 weeks i can have a look at mine. what yours is doing does not sound unusual however it is touch screen. i also cant remember if the cd is autoplay.
im sure all shall be revealed in time, dont panic just yet..
Thanks a bunch
No panic yet,just want to look at any options availible.
I am going to see if i can get any luck with trying to fix the original screen,as dumb as that is ,I think it would be cool if it a tually worked
Paulo
  • 5 years later...
On 11/16/2012 at 11:34 PM, DaveB said:
Thanks Brendan. I eventually bit the bullet and bought a conversion harness (Akai brand I think) from Japan, but it was your details of the actual *controller* unit which were the final pieces to the puzzle I needed. Awesome stuff by the way to wire your own conversion harness.
The controller unit is a black box squeezed in just to the left-hand side of the foot E-brake pedal (the auto stagea's equivalent of a handbrake) with respect to the driver. Unfortunately, the plugs on this unit are the same as on the xanavi panel itself, and so the harness fits at both ends. Except there are only 2 plugs on the xanavi end. So after hunting for this box, SOMEhow managing to unplug the 3 connectors and connecting them to the aftermarket harness (I now realise why it's a metre long!), we now have a working standard climate control in a xanavi car. So it turns out it is possible! Hurrah.
My Xanavi has finally died. So I have bought the parts needed and the cable from japan but I am not sure what the "controller" looks like.
My car is 1998 Series 1 WGNC34 25tX Four and I have the 2 plugs that match up with the Japanese harness but no 3rd.
I pulled apart the bottom of the dash... but before I remove the instrument cluster... would this be the "controller" I am looking for?
This was below the Xanavi area right down behind the cigarette lighter. I didn't see it at first and it wan't till I pulled it out I could see the Xanavi on the side but having the word "Relay" through me. The plug is not the same.
As far as I can feel the wires seem to just go towards the fuse box and no other unit I can see.
Antony
Edited by ant0ny
  • 2 months later...
  • 9 months later...
On 8/8/2019 at 3:27 PM, ant0ny said:
Ok moving some bits out of the way I found it.
You don't happen to know where to get these harnesses for the conversion by any chance. I've tried heaps of links and there seems to only be extensions available now
  • 1 year later...
Hey I didn't get this before now. No I just followed links from the forum then did a bit of translation etc... I did contact the guy selling and sent him my cars VIN etc to confirm before purchasing.
  • 9 months later...
 Share
    • I have a radium fuel rail on my Greddy manifold and used the supplied radium fuel injector to manifold adapters (The round green things pictured). I did always wonder if you could just go ahead and use the second lower hole like you're doing... Wouldn't thicker o-rings solve your issue?
    • From what I've seen and experienced first hand with those powder extinguishers, they're good to use to break a window and escape the car, and half the time then do f**k all to stop a fire. You just need much more than 1KG worth of powder. Not to mention, half the time it's an engine bay fire, and you can't easily, and do not want to completely open the bonnet, so you're left pretending to be an American Infantry... Spray and Pray baby!   And then 100% that shit is really destructive afterwards!   Realistically, those little ones at a race track might help you keep the fire from growing and give the fire marshal / truck a chance to actually get to you with their multiple large bottles.   For a road car, these days, prepare to deboard as quickly as humanly possible, and move to safety. Allow insurance to fix replace it (unless it's like a rare classic etc, then do nearly everything possible to save it!) Keep the little extinguisher with you to help protect other things around you from burning while you stand there singing "How can we sleep while our beds are burning?"   Secondly, powder extinguishers I freaking hate for indoor use, (this isn't really relevant to a car) as you will get a powder fog around you, and it can be disorientating.   When I did fire training when at BlueScope Steel, they have (had?) their own fire brigade on site. We did all the training, and at the end we were told, "If it's an indoor fire, and you need to use a powder extinguisher, we as the fire brigade would rather you just exit the building, you're more likely to get lost in the smoke and powder fog than do much help, so just GTFO" And pretty much that was what they said for most other fires too, grab extinguisher, if it's much more than paper in a bin fire, use extinguisher to get you and others out of the building to safety...   Part of me wishes when my Skyline caught alight many moons ago, I let insurance sort it out, instead of putting the fire out... part of me now says "But I've saved a classic before it was a classic!"
    • Hi all,  I have a older model of the Greddy Front facing intake on an RB25DET NEO Head. I've bought aeroflows fuel rail and injector kit (1000cc Bosche injectors) and I'm unsure if the fitment is correct. The injector o-rings fit in the intake hole but it's not snug. I can very easily rotate the injectors even when the fuel rail is mounted. The kit also came with multiple adaptors, they dont make it any more snug and using them raises the injectors up and i cant mount the fuel rail. I hope this makes sense I've asses a few photos.    Thanks so much guys.
    • So, to run the 4g aerials to the booster, I had to get access to the rear bulkhead....bit of a mission. Hot tip, don't offer to help change the rear shocks for a mate with a v37.... Remove seat base, 2 clips that slide forward to release it the it lifts straight out Fold down rear seat (pull in from boot) The side bolster of the rear seat is not connected to the middle parts that fold. To remove unbolt at the bottom bolt then push it up off the top hook Then there is a plastic surround behind the seat back, 2 pop out clips, 2 bastard clips, some swearing at it is out Pop the rear seat latch surround off Remove door surround lower trim then side trim  Remove c pillar trim - 4 clips, pull inwards not forwards Remove metal brace - 5 bolts 1 nut Then you have got to the rear strut top...what a pain!
