(updated 21/03/08)
Hi Guys - Just thought I would do a fresh post for some of the gear I have for sale (update the new items I have added + delete the stuff that is sold) - Here We GO:
Nismo RR581 Turbos (pair of to suit RB26)
Rated at ~640hp
FULLY REBUILT and balanced by garrett dealler
$1950 ono
(these were over 4k from nismo when they were new)
Tuned CHIP to Suit GTR32 (or 33 if you use R32 ECU)
Has SAFE improved fuel / ignition maps
Speed cut removed
Rev Limit Raised
Ideal for lightly modded GTR
Big difference in power and torque compared to stock
Comes as chip only (can probabley find a socket for it as well)
$SOld
GTR BOV PIPE
(the pipe your BOV's Mount to)
$Sold
Trust "style" Oil Cooler / Filter Relocator Kit
New
$250
Stock GTR ECU
Good Working order
$200
Stock GTR Injectors
440CC x 6
$300 set
RB26 Rocker Cover Gaskets
Brand New from nissan
With Half moon seals
$70 the set
RB26 / RB25 Exhaust cam gear
Modified stock item
Bolt / locating holes slotted (in a mill - pro job)
Allows for adjustment
$50 ono
RB26 SUMP / DIFF Carrier
Good Condition
$offers (no idea what this is worth)
REBUILT R33 N1 TURBOS
14411-24U10
.42 comp version
360 Degree Thrusts
2 position actuators
All new bearings and seals
Rebuilt an balanced by Garrett Dealer
With warranty
$Sold pair
Rebuilt GTR Turbos
N1 Spec Turbines / exhaust wheels
360 Degree Thrusts
with warranty
$1500 pair
Factory GTR Blow Off Valves (2 sets)
Good Working Order
Includes Mounting Bracket
$150 pair - without return pipe
$200 pair - with return pipe (no pictured)
R33 GTR CRANK
Light Pick up No 6 B/E bearing
Suit U/S bearings (can supply if needed)
Otherwise good cond
$495
DUNLOP LEMANS LM702 235/45 17 Tyres x 2
Excellent Tread Left - Even Across Tyre - 85 ~ 90%
$SOld
"FUJISAKI SPL" Tuned / Re-Mapped ECU GTR32 / 33
Improved power and torque
Speed cut and rev limit lifted
Boost cut Lifted
$295
Veilside VX ROM Tuned ECU GTR32 / 33
Boost cut Lifted
$295
Stock R32 GTR wing
Blue - few bumps and scratches - suit repainting
$decided to keep :)
Apexi Super Suction Kit GTR32 / 33 and Air Flow Meters
Includes:
Hard Pipes
Silicon Joiners
Hoseclamps
$SOLD
2 x 80mm RB25 air flow meters
2 x AFM Plugs
$300 lot
(great upgread for GTR - less than half the price of buying Z32's and will still support 600+ HP)
Will post pics later ;)
Edited by Antimatter
Steve
Oil cooler is some no-brand trust / HKS copy - looks good though - has blue / red alloy fittings like the HKS one, remote filter boss and 3 long hoses. Paid $350 for it but I am not sure I will get round to fitting it.
With regard to pics - will try to get to them ASAP
Thanks guys!
Steve
  • 3 weeks later...
I have some pics - will email u soon
hey any pics of the Gtr BOV's?
Does it come with all the pipes/brackets required to fit them
Thanks
[email protected]
  • 1 month later...
  • 5 weeks later...
    • Getting the setup right, is likely to cost multiples of the purchase price of the vehicle.
    • So it's a ginormous undertaking that will be a massive headache but will be sorta cool if pulled off right. And also expensive. I'm sure it'll be as expensive as buying the car itself. I don't think you could just do this build without upgrading other things to take the extra power. Probably lots of custom stuff as well. All this assuming the person has mechanical knowledge. I'm stupid enough to try it but smart enough to realize there's gonna be mistakes even with an experienced mechanic. I'm a young bloke on minimum wage that gets dopamine from air being moved around and got his knowledge from a Donut video on how engines work.]   Thanks for the response though super informative!
    • Yes, it is entirely possible to twincharge a Skyline. It is not....without problems though. There was a guy did it to an SOHC RB30 (and I think maybe it became or already was a 25/30) in a VL Commode. It was a monster. The idea is that you can run both compressors at relatively low pressure ratios, yet still end up with a quite large total pressure ratio because they multiply, not add, boost levels. So, if the blower is spun to give a 1.4:1 PR (ie, it would make ~40 kPa of boost on its own) and the turbo is set up to give a 1.4:1 PR also, then you don't get 40+40 = 80 kPa of boost, you get 1.4*1.4, which is pretty close to 100 kPa of boost. It's free real estate! This only gets better as the PRs increase. If both are set up to yield about 1.7 PR, which is only about 70 kPa or 10ish psi of boost each, you actually end up with about 1.9 bar of boost! So, inevitably it was a bit of a monster. The blower is set up as the 2nd compressor, closest to the motor, because it is a positive displacement unit, so to get the benefit of putting it in series with another compressor, it has to go second. If you put it first, it has to be bigger, because it will be breathing air at atmospheric pressure. The turbo's compressor ends up needing to be a lot larger than you'd expect, and optimised to be efficient at large mass flows and low PRs. The turbo's exhaust side needs to be quite relaxed, because it's not trying to provide the power to produce all the boost, and it has to handle ALL the exhaust flow. I think you need a much bigger wastegate than you might expect. Certainly bigger than for an engine just making the same power level turbo only. The blower effectively multiplies the base engine size. So if you put a 1.7 PR blower on a 2.5L Skyline, it's like turboing a 4.2L engine. Easy to make massive power. Plus, because the engine is blown, the blower makes boost before the turbo can even think about making boost, so it's like having that 4.2L engine all the way from idle. Fattens the torque delivery up massively. But, there are downsides. The first is trying to work out how to size the turbo according to the above. The second is that you pretty much have to give up on aircon. There's not enough space to mount everything you need. You might be able to go elec power steering pump, hidden away somewhere. but it would still be a struggle to get both the AC and the blower on the same side of the engine. Then, you have to ponder whether you want to truly intercool the thing. Ideally you would put a cooler between the turbo and the blower, so as to drop the heat out of it and gain even more benefit from the blower's positive displacement nature. But that would really need to be a water to air core, because you're never going to find enough room to run 2 sets of boost pipes out to air to air cores in the front of the car. But you still need to aftercool after the blower, because both these compressors will add a lot of heat, and you wil have the same temperature (more or less) as if you produced all that boost with a single stage, and no one in their right mind would try to run a petrol engine on high boost without a cooler (unless not using petrol, which we shall ignore for the moment). I'm of the opinnion that 2x water to air cores in the bay and 2x HXs out the front is probably the only sensible way to avoid wasting a lot of room trying to fit in long runs of boost pipe. But the struggle to locate everything in the limited space available would still be a pretty bad optimisation problem. If it was an OEM, they'd throw 20 engineers at it for a year and let them test out 30 ideas before deciding on the best layout. And they'd have the freedom to develop bespoke castings and the like, for manifolds, housings, connecting pipes to/from compressors and cores. A single person in a garage can either have one shot at it and live with the result, or spend 5 years trying to get it right.
    • Good to know, thank you!
    • It's a place for non car talk. There's whoretown which is general shit talking. But also other threads coving all sorts of stuff(a lot still semi car related)
