I have HKS Hyper D shock absorbers F&R of my skyline.
I was wondering if they are servicable and if so, where can I
send them?? I live in Mount Isa and I would also like to know the nearest HKS
dealer or service agent.
Thanks,
Shaun :banana:
https://www.sau.com.au/forums/topic/205935-suspension-repairs/
hey hey say hi to kev at autobarn for me, and tell whitey to keep the gtr :wave:
there is a place in qld www.shockreco.com.au/ ive used a few times and they are a bit hit and miss, i had some gpsports done there that came back worse :blush:
the other option is fulcrum i think they will do them but expect to pay more.
  • 2 months later...
The question of servicing shocks comes up a lot and is usually met with poor response, the reasons why;
1. Each shock brand is different, so the parts are almost guarateed to be different. No one can afford to to carry spare parts for every brand of shock. Plus it is not unusual for special (expensive) tools to be required.
2. Most Japanese brands of shock don't have spare parts. They are not sold separately by the manufacturer, so no one can buy them. Plus very often the shock bodies are sealed at the time of manufacture, the don't have easily accessible internals. No service manuals are available. Their thinking is "buy new shocks" when the old ones are worn out.
3. So a lot of shock reconditioners use second hand parts in the service. They get 2 or 3 sets of one brand and make 1 good set out of them. That's why the success rate of getting shocks reconditioned is patchy, you might be lucky and get good second hand parts and you might not.
3. The majority of the value in shocks is in the parts that wear out. The shafts, the bores, the pistons and their valves, that's where the money is and they are what wears out. Add labour to the cost and you end up with more than the cost of new shocks.
4. Sometimes you can be lucky and the only thing wrong with a shock is the seals are damaged. Then you need to be lucky again and hope that the seals are a standard size, which doesn't happen very often with Japanese shocks. The process is to replace the damaged seals, new shock oil and regas with nitrogen. Based on my experience that would happen less than 0.1% of the time. Why? Well when the seals let go the nitrogen escapes and the shock looses a lot of its efficiency, it moves up and down a lot freer. Quite often so much so that bump stops start wearing out. When the bump stops are gone, the piston starts slamming into the top and bottom of the shock tube. That very quickly destroys the valves and the piston itself. Plus the resulting bits of metal score the bores on the shock tube and it becomes useless. So you have very short timeframe between seal failure and total shock worthlessness, the last piece of luck is noticing the damaged seals in that short period of time.
5. The more sophisticated shocks (Bilstein, Koni, MSA, Sach, Penske etc) are designed to be serviced. Their manufacturers offer spare parts and service kits. They have designated agents who carry the range of spare parts for their brand, they have the special tools and the manuals. They have shock dynos to confirm the results, which is essential, unmatched shock pairs are not a good thing.
Cheers
Gary
Gary,
Do Bilstein, Koni, MSA, Sach and Penske make a track shock and spring combo or coilover set up for skylines?
What are our other options other than the jap ones for track use?
Cheers,
Ryan
H Ryan, I specify Eibach/Bilstein sets for Skylines almost every day for circuit racing, drag racing and drifting. We use Konis in lots of applications but I have tried their offerings and for R32/33/34's and the bottom line is the Bilsteins are a superior solution. The Bilstein/Eibach combo's work out around $2,200 depending on the specification. I have recently arranged some sets of R33GTR, R34GTT and R34GTR Bilsteins in the PS9 style with track day specification, they will be around $2,900. For MSA (nee Proflex) you are looking at around $8K for the double adjustable, remote cannister and $9.5K for triple adjustable. Penskes are around $11K which is similar to the Ohlins (that's Swedish Ohlins, not Yamahas). I am doing some work on the Sach range, they are 5 way adjustable so the engineering is substantial.
Cheers
Gary
  • 1 month later...
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
