any chance of separating the filler panel matey?
im hopeing to enter my R30 hatch in the skyline nationals in vic at the end of july.... would luc yo have the front finished by then
the R34 side-mount cooler im useing fits under the iron mask headlight alot better than the oz spec series 1 or 2 (i have both)
if i have to use the oz spec then i need to move my air con dryer or something (cant remember exactly the name), which i dont wanna do as i like the air cons!
or im slightly considering useing it as a top mount over where the stock airbox lid is...
SO.... whats the go
gday, sorry mate dont want 2 seperate as it was the hardest bit 2 get and p have trouble selling the rest without it. unless i was offer'd a stupid amout for it 2 offset what ill lose selling the rest seperate...
ive got a front mounted 1jz cooler in my dr30 atm that im selling due 2 upgrade includes polished alloy pipes, silicon hoses and bolts 2 the front side of radiator mounting points so all u need is long bolts and nuts. its for fj20et with tb and turbo in stock position, will include custom alloy turbo intake pipe with hks pod thingo $250 no a/c space tho...
jon.
    • Hey all, I'm working on a project car and I believe I made some mistakes. I'm looking to remove the clear coat from my car on most panels (except for panels where the paint has blistered, I will sand this), but wanted to know if these steps are correct?   1) Get a red scuff pad (abrasive one) instead of sand paper to remove the shine from the surface 2) get 400 grit sand paper and go over the entire car with a random orbital sander so the surface is smooth and the primer can grab onto something 3) On the blistered paint, go over it with around 120 grit sand paper, go to 240 to smooth out the scratches, then finish on 400 grit. Anything to add in here or any feedback?
    • Agreed, another vote for the Haltech CAN wideband.  No voltage offset errors is a beautiful thing.
    • Just get a Haltech CAN wideband, no need to wire any delay circuits, or relay, etc. Since I've moved to a Haltech CANbus wideband, I have not replaced a single sensor for over 5 years (if not longer, can't remember when moved to Haltach).
    • Small analogue delay circuit with a relay. Just need a trigger, say, fuel pump running for more than 5s or so? Or, you could go full mental and write a sketch for an Arduino.
