hi all,
As some of you may or may not know the SAU VIC AGM is coming up in mid March and the new Committee is elected.
This is important for all members as you have a chance to make a decision for the clubs direction and future.
If you haven't already read the nominations and current positions available you should familiarize yourself for these.
Voting is only eligible to current financial members of SAU VIC and voting will be done for all nominated positions on the night of the meeting.
For current nominations, information and listings of the official roles please check out
http://www.skylinesaustralia.com/forums/20...it-t203698.html
Note: this is only available to SAU VIC members (paid membership)
Vote #1 - R31Nismoid (Ash) for President
I stand by Ash running for president for 2008/09 calendar year and believe he will do a great job.
I believe he has the clubs background, the clubs foundations, its member base and extensive knowledge of what's worked in the past and what hasn't.
For this I believe he is the most suitable candidate and he has my vote as President.
I would love to stand by and support as Vice but I am unable to commit my time due to the other personal commitments.
This isn't to say the other candidates are not suitable - you should make that decision yourself on who is suitable - this is just my "campaign".
This is not propoganda - just expressing my support
https://www.sau.com.au/forums/topic/205944-the-presidents-campaign/
i was gonna vote justin911....but ok ash got my vote
hehehe...i can just imagine ash's thankyou speech after winning:
".....and I vow to make the search feature more user friendly for everyone to enjoy.........."
Hmmmm
I see where this thread is going...
You two need to cut to the chase and get it over with. It is valentine's day tomorrow.
Is that you on the left James? The guy with the hard on?? call me sometime, your hot :)
yes... i was joking... please no more gay porn on SAU, at least put lesbians.....
erm.... thanks for the unexpected support there Paul and others, or lack thereof.
I do live in Windsor don't forget, h0m0 pic's are a part of daily life... :sorcerer:
Dunno what else to say, kinda didn't expect to see a thread about me running for Pres he he...
Hopefully the AGM gets a big turnout and the view of the members is reflected well in their choices for Exec positions, as that will be the best possible outcome i hope.
    • Welcome.  800hp should be a bit of weekend fun!
    • I'm going with "Just run two gates". Fix the problem conclusively. It's the only way you'd ever truly know, right?. This is all pretty much splitting hairs. Even the extreme example where it takes two whole seconds at 100kmh or something sounds monstrously dubious. And anyway, when you're punching the throttle when you 'need' this power, you aren't at 2800rpm in the wrong gear. Test it at 5600rpm in 3rd gear, when you're traction limited punching out of a sweeper. Much difference there when you account for traction?
    • And the full R32 GTR wiring diagrams are also freely available. Hmm.... there's supposed to be an auto replace that would have linked the thread. Here it is, manually
    • Ahh...should have been clearer ~ there's 2 ... SMJ = super multi junction (connector)...   ...this is connector 6 & 25 in above image -- body harness to engine loom (6) & body harness to main loom (25) Headlights go to front via connector 6 ; fuel gauge goes to tank sender via connector 25  ...like I say this is R33 diagrams, but at a pinch R34 won't be too far different. *IF* the two ground faults are related, this can be the only place where both wires converge (as one runs to the back, the other to the front)... ....thing is, you probably need to establish if the faults are related (unless you examine that area and find obvious chaffing on the looms there to body ground)....*IF* the fuel gauge is still broken (full needle deflection), I'd be headed for the boot, remove fuel sender wire, key on and measure the voltage there ~ it should be roughly 10volts. If that's ok, check sender to ground resistance...if this is a dead short to ground (and there's fuel in it), then sender has failed or something funky has happened to wiring in the tank. edit: ahh...rereading the thread, this is R32....above fuel sender test still valid tho'
    • I just changed the timing belt on my RB25DET NEO and wanted to get some opinions. I’ve been super cautious, did a lot of research, and took my time. I’ve driven the car, and it runs fine. After warming it up, I revved it to 8000 RPM a few times—no issues, everything held up.   After the drive, I heard a noise that I think is either the clutch or possibly a tight accessory belt. It’s not constant, just comes and goes.   I took the timing cover off to double-check everything:   Belt is on properly, Tensioner is tight, Did the 90-degree twist test—belt isn’t too tight or too loose.     What still worries me is that I noticed the belt seems to sit a little toward the front edge of the gears, especially on the idler pulley. It even looks like it’s slightly coming off the edge there. Is that normal?   My old belt (5 years old, ~3,000 miles) also showed a bit of wear on that same edge, so maybe it’s just how it sits? I’m probably overthinking this, but since it’s my first time doing this on a NEO and the engine is forged, I really don’t want to mess anything up.   Also, I’m thinking of swapping to a clear front timing cover with the glass window. Would you recommend NITO or HPI? HPI looks reputable and their covers have 2.5mm thickness, but not sure if there’s a real difference between the two.   Any advice or reassurance would be much appreciated!
