My older brother (22) has just sold his sil-eighty and is now looking for a decent car to buy.
He Does'nt have an account here so Im posting this for him, Basically his choices are as follows:
1989 R32 GTS-T Skyline
1989 300ZX TT
1989 RX7 Infini
That said can someone tell me the difference between the Infini and the normal RX7's ?
I belive he is leaning towards the 300ZX TT, he likes the look of it and the Twin Turbos help his decision :D
Anyways what do you think ?
https://www.sau.com.au/forums/topic/20595-car-decisions/
About the '89 FC's...
The '89 GT-X had 185ps standard, 15in alloy wheels, electric mirrors, an LSD... shit like that, not so special.
The '89 Infini III was based on the GT-X, with the addition of BBS alloys, Momo steering wheel and gear knob, power-up to 215ps and 28kg/m torque, a front strut-tower bar (strut brace? can't remember wot you lot call 'em!!) and more shapely bucket seats. Definite pick of the FC range if you can get one.
/Rezz
https://www.sau.com.au/forums/topic/20595-car-decisions/#findComment-431557
People have said that the TT is hard to work on, because of the crampt engine bay. That said my mate has a TT and he reckons its not too bad. But like Waz said, appearances count for alot; if you like the look, then that may be enough.
https://www.sau.com.au/forums/topic/20595-car-decisions/#findComment-433306
  Quote
Originally posted by WazR32GTSt
3.0 TT + 1800kgs = very bad fuel economy
Were'nt the 2-seaters 1520(MT) 1530kgs(AT), and the 2by2's 1550(MT) 1570kgs(AT)?
1800kgs is Commodore territory...:mad:
https://www.sau.com.au/forums/topic/20595-car-decisions/#findComment-433325
  Quote
Originally posted by Parag0n
Nah im pretty sure the 300ZX TT weighs at 1490kg
I got those figures from the factory catalogue dude :mad:
I'd put my money on the 300ZX TT in a straight line against a GTS-T...
https://www.sau.com.au/forums/topic/20595-car-decisions/#findComment-433593
some Spec's on Z TT
89 – 98
3.0lt DOHC 24V twin turbo 6cyl
2Dr Coupe(2 seats or 2+2)
RWD
1490kg
208kW
388Nm
5spd Manual, 4sp Auto
double wishbone
f & r vent discs
great power ... to weight ratio, with reports of 13 second standing start quarter mile times in standard form ...
https://www.sau.com.au/forums/topic/20595-car-decisions/#findComment-433631
E-CZ32 E-GCZ32
@ƒ~ƒbƒVƒ‡ƒ“iAT/MT/CVTj 4AT/5MT/| 4AT/5MT/|
@VŽÔŽž‰¿ŠiiAT/MT/CVTj 4,100,000/3,950,000/| 4,400,000/4,250,000/|
@ƒhƒA” 3 3
@‹ì“®•ûŽ® FR FR
@æŽÔ’èˆõ 2 4
@‘S’·‚˜‘S•‚˜‘S‚immj 4310‚˜1790‚˜1245 4525‚˜1800‚˜1255
@ƒzƒC[ƒ‹ƒx[ƒXimmj 2450 2570
@Žº“à‘S’·‚˜Žº“à‘S•‚˜Žº“à‘S‚immj 945‚˜1505‚˜1045 1580‚˜1485‚˜1045
Sorry about the Japanese, but these figures are copied from a scanned Fairlady Z catalogue... wieght is below.
@ŽÔ—¼d—Êikgj(AT/MTj 2-ƒV[ƒ^[1520/1510, 2by2 - 1570/1550
@Å’á’nã‚immj 130 130
@Ŭ‰ñ“]”¼Œaimj 5.4 5.6
My bad before, I said 1520/30kgs for the ‚Q seater.
https://www.sau.com.au/forums/topic/20595-car-decisions/#findComment-433657
he's trying to post asciii porn..
Personally I don't like the looks of the 300zx anymore. I think i once did. The VQ30DETT can be made to go very hard, but it is kinda heavy and probably bit boat like in the handling..
I'd just go the 89 R32 GTS-T as mods and things should work out a bit cheaper, and the knowledge base is larger for skylines probably.. but be careful a bit of the 89 vehicles.
My rec is to stay clear of the Rx7.. rotaries can have lots of problems, especially if they're getting on a bit in age.
https://www.sau.com.au/forums/topic/20595-car-decisions/#findComment-433707
    • This is lower price now given apparently nobody wants these or needs them. It's 550 but if someone sees it on SAU and wants to make an offer, please do so.
    • LS is a good motor, but it hurts my soul when I see it in a RB. Guess it fixes the oiling issues lol.
    • I'm confused. Does this qualify as "Gregging" or are you somehow avoiding the Gregging?
    • More assembly going on, with all sorts of "bolt right on bro" scenarios going on here. Smartly, PTV clearance was checked. And I say smartly because it turns out that the intake was 0.009" from piston meeting valve. This is 0.23mm. This is very not okay. A fast meeting was facilitated between engine builder in Australia and engine builder in the USA which was actually incredibly helpful and constructive actually, various ideas thrown around to get around this issue including: 1) Retard the cam timing which would have brought the exhaust valve closer to meeting piston (it was 0.065") which was uncomfortably close to begin with, and change the cam profile making it 'laggier' 2) Much larger head gaskets which would reduce compression, but half the point of this was to increase compression. 3) New set of pistons ($$$$$$$$$$$$$$$$$) 4) All of the above 5) Get ghetto The concept is you get sticky sandpaper and stick it back to a valve, slightly larger than the valve you/I'm using, like say from a LS3/rectangle port head. You now have a very super advanced flycutting tool to modify your pistons in your block. Then you install it in your head, and attach the other end of the head to a drill. Then you just replicate your valve smashing into a piston with your spinning drill.   This is the result. Repeat many times. It is strongly recommended you have some kind of fixed stop when doing this for extremely obvious reasons because if you press too hard then you're well into apocalyptic repercussion land. The minimum clearance on the intake valve is now 0.075" this is still in the "Too close to be really comfortable" and into "It should be fine" land. Supposedly in the real world the clearances will be slightly bigger. Guess this is what happens when people push envelopes for N/A engines instead of adding boost! Time to move onto the new, upgraded, higher ratio roller rockers from Yellaterra, all tapped and threaded with a stronger bolt for better stability. Very nice. Lets see how they fit. For f**ks sake. Time to bring the grinder out for these aftermarket, machined and CNC'd heads. Looks like the new, beefier rocker from YellaTerra has gone from Bolt on part to "Bolt on part". Well, lets see how this bolt on crank scraper and windage tray goes then, shall we? There actually is more clearance than they specify for this thing, but seeing it all move as you check it is terrifying when you see it all so very very very very nearly hit things. But after all, this is what the item is designed to do after all and actually did bolt on perfectly and have enough clearance to everything and some very clear and direct instructions. So +1 to Improved Racing I suppose. As above with the windage tray on. Photo of breaker bar wonkiness for added lols. Next up: Oil pump/front cover/water pump/sump and then it's time to actually install the heads, pushrods, head bolts, valve cover gaskets and such is all there and ready to go. (except the oil pump bolts which were previously longer for more clearance with the previously perfectly installed double row timing chain). There's definitely a sense that someone other than us has been here before and done everything perfectly, or at least considered it and came up with working solutions. Perhaps the previous cam was 6deg advanced to avoid PTV issues with the milled stock heads? In any case when I attempt to sell this stuff the buyers are going to be very directly informed.
    • my catch can is pretty easy to empty but it overflows due to the blowby/crank case pressure etc. max I have drained is ~600ml even with a ~2.3L capacity. So it is not just about having to drain it out its the mess it makes down the firewall and under the car and rear passenger tyre from the overflow oil being blasted by screamer + air in general. Ending up on the ground cleaning the oil up and having oil on your arms when everyone else can chill and watch the other sessions gets old fast
