Hey all,
Do anyone know the size of the standard RS4 S injectors. I am currently running approx 190rwkw with a pfc, trust front mount, full exhaust and 12.5psi
However I am getting injector duty cycles of up to 98%
I have just replaced the fuel pump however was told that the standard pump was working fine ( I replaced it really for future mods) which made no difference.
Are the stagea injectors smaller than others? I was under the impression that the stock turbo would not max out the standard injectors, and it was only until you replaced the turbo that the injectors needed upgrading.
Cheers
Dave
https://www.sau.com.au/forums/topic/205977-s2-rs4-s-injectors/
You are getting close to max out the injectors. you could get a bit more out of them with a adjustable fuel reg.
At 98% the is no room for error. I would think with prolonged use your engine would have a short life.
The injectors in the neo are 350-370cc, cannot remember, I think they are slightly less than R33 370cc. Quick fix, turn the boost down, short term fix fit fuel reg, long term bigger injectors. I am getting at the moment 185awkw (249hp) with larger turbo, cams and blitz 525cc injectors with approx 68% duty cycle an a very safe tune.
Cheers, I think ill turn down the boost a tad. I have more mods to come soon including a larger turbo and injectors Z32 etc.
Im not going to install a FPR because of the future mods, if I was going to leave the car as it is then I would have one installed.
What sort of turbo are you running and at what boost?
Apexi ax53b70-p25 380ps
Tomie type b 260 deg cams
Boost set at 15psi, but not holding to redline, drops back to 12.5. Need to get this sorted and run 17-18psi and a bit more timing. Runs approx 11.7:1 AFR. Tuner was worried about pushing the neo too much.
Eventually the turbo will run out of puff, so maybe upgrade to a GTRs
IF you ever do sell the Apexi turbo, let me know
:blush:
how are you going about fixing the boost drop? mine drops from 16 to 13psi, hopefully the hks actuator fixes it.
Some people on the forum, very limited amount with the apexi are getting around 250rwkw on R33 25's with full mods.
Tuner thinks it is the actuator not holding, so I have been chasing another from another member that blew his turbo running 25psi. They actually have a ceremic exhaust wheel supposedly, but are way stronger than the factory nissan wheels.
It does pull well from 3500rpm. The apexi's are reportedly to have good midrange and the cams help out well
I was hoping to get to the track to see what it would do, but it keeps raining. That is is where the true performance is shown, not by a dyno result.
I saw your dyno sheet, and it looks like you have a lot of boost drop off up top which if correct will see a large power gain.
The tuner spent over an hour playing around and adjusting the boost controller and the actuator, but could not get it right. So hopefully when sorted there will be an extra 20-40kw.
DEATSCHWERKS injectors look the shitz
the ones I got delivered this week are high-flowed 480 to 550cc items
Im sure they would be able to do top feed.
they are in the States, email and ask for david or mike and say Brendan from South Australia referred you.
I would suggest the Blitz 525cc over the Deatschwerks, as the blitz are new and the same price delievered from greenline and are not reco highflow's. Just my opion.
for sure
I went based on price - and factored in the fact that Im only after 20 more a/rwkw anyway.
they charged me bugger all, around $400 all up (they stuffed up, I wanted custom 450cc items they said have 550cc no extra)
I think ill leave t up to my tuner, I have previously used ~560cc denso injectors in an R33 which were fine for my application. Im building the car for the GTRS at approx 18psi however want a little room to move if I decide to go a bigger turbo again later on down the track.
    • Ha ha, yeah, I've had one following me around in my parts boxes since about 2007 I believe. Just a little iddy bit hole drilled in the one I have to let it vent out once pressure was removed from the engine side. Still no idea what I'd put it on, ha ha.
    • Just read this... Just a little bit of a wild one! Do you think the driver was testing out a new feature/device for how to lose the cops in a high speed chase?   I also suspect, if the box has a road sweeper that does magnetic metal pick up, he does a LOT of work in the machining industry. Which is what most of that looked like, machining chips from a mill or lathe. And I bet they're RAZOR sharp! And from an environmental perspective they really do need to actually collect all of those little pieces too. I wonder how many people still cop flat tires over the coming months on that road?   As for insurance company, yeah, it'd be interesting to hear what they say to the owner. But realistically, he's right, that "It's his fault". In the way that, it was his truck that spilled it, so they need to clean it up. However, neither he, nor his insurance company may bear the end cost if they do an investigation and find out it was caused by someone elses negligence (And they know who)...
    • Yeah, no matter what bad things people can say about Julian from Autospeed, he at least was capable of thinking and his inclusion of a check/relief valve in the plumbing for the Audi boost controller, that I made a copy of and used for years**, completely eradicated that problem. **It's still lying on my workbench where I put it about, um, 18 years ago and have never found a home for it!
    • I didn't actually know this! I've seen photos of the H1, mainly outside shots, and they just look "different". I guess there'd be a few little changes like nicer rims, and probably the fact they have nicer looking paint with some depth and shine, which will make any vehicles body look different to the very flat colours of the defence force.   I've watched the guys on GHPC convert their Humvee to LS1, and they've done some really nice front shock upgrade. I'm waiting for the next video on it with the rear end done. I can't remember if they've already done it, or I dreamed it, but I believe they're also supercharging theres. They will be in the future doing proper long travel suspension too.   If you ditch out your big V8, as rubbish as it must be, send it to my place. I'll let the unreliable V8 motor and box be here. I just like V8s... So I'll find something to do with it... Even if that something is just taking up valuable space in the yard. I might have something Skyline I can send back in payment... Or even Ford Barra motors  (From memory you're in Canada yeah?) So you can then play with the legendary Aussie 4L version of an RB...  Except they don't have that distinctive random miss at idle like the RB25 does.
    • Or you mean the age old problem of early 2000's manual boost tees, where they never let the pressure out of the line between the boost tee, and the waste gate, so after your first trip on boost, the damn wastegate liked to stay open and be laggy on gear change?
