Hey all,
Do anyone know the size of the standard RS4 S injectors. I am currently running approx 190rwkw with a pfc, trust front mount, full exhaust and 12.5psi
However I am getting injector duty cycles of up to 98%
I have just replaced the fuel pump however was told that the standard pump was working fine ( I replaced it really for future mods) which made no difference.
Are the stagea injectors smaller than others? I was under the impression that the stock turbo would not max out the standard injectors, and it was only until you replaced the turbo that the injectors needed upgrading.
Cheers
Dave
https://www.sau.com.au/forums/topic/205977-s2-rs4-s-injectors/
You are getting close to max out the injectors. you could get a bit more out of them with a adjustable fuel reg.
At 98% the is no room for error. I would think with prolonged use your engine would have a short life.
The injectors in the neo are 350-370cc, cannot remember, I think they are slightly less than R33 370cc. Quick fix, turn the boost down, short term fix fit fuel reg, long term bigger injectors. I am getting at the moment 185awkw (249hp) with larger turbo, cams and blitz 525cc injectors with approx 68% duty cycle an a very safe tune.
Cheers, I think ill turn down the boost a tad. I have more mods to come soon including a larger turbo and injectors Z32 etc.
Im not going to install a FPR because of the future mods, if I was going to leave the car as it is then I would have one installed.
What sort of turbo are you running and at what boost?
Apexi ax53b70-p25 380ps
Tomie type b 260 deg cams
Boost set at 15psi, but not holding to redline, drops back to 12.5. Need to get this sorted and run 17-18psi and a bit more timing. Runs approx 11.7:1 AFR. Tuner was worried about pushing the neo too much.
Eventually the turbo will run out of puff, so maybe upgrade to a GTRs
IF you ever do sell the Apexi turbo, let me know
:blush:
how are you going about fixing the boost drop? mine drops from 16 to 13psi, hopefully the hks actuator fixes it.
Some people on the forum, very limited amount with the apexi are getting around 250rwkw on R33 25's with full mods.
Tuner thinks it is the actuator not holding, so I have been chasing another from another member that blew his turbo running 25psi. They actually have a ceremic exhaust wheel supposedly, but are way stronger than the factory nissan wheels.
It does pull well from 3500rpm. The apexi's are reportedly to have good midrange and the cams help out well
I was hoping to get to the track to see what it would do, but it keeps raining. That is is where the true performance is shown, not by a dyno result.
I saw your dyno sheet, and it looks like you have a lot of boost drop off up top which if correct will see a large power gain.
The tuner spent over an hour playing around and adjusting the boost controller and the actuator, but could not get it right. So hopefully when sorted there will be an extra 20-40kw.
DEATSCHWERKS injectors look the shitz
the ones I got delivered this week are high-flowed 480 to 550cc items
Im sure they would be able to do top feed.
they are in the States, email and ask for david or mike and say Brendan from South Australia referred you.
I would suggest the Blitz 525cc over the Deatschwerks, as the blitz are new and the same price delievered from greenline and are not reco highflow's. Just my opion.
for sure
I went based on price - and factored in the fact that Im only after 20 more a/rwkw anyway.
they charged me bugger all, around $400 all up (they stuffed up, I wanted custom 450cc items they said have 550cc no extra)
I think ill leave t up to my tuner, I have previously used ~560cc denso injectors in an R33 which were fine for my application. Im building the car for the GTRS at approx 18psi however want a little room to move if I decide to go a bigger turbo again later on down the track.
    • I'm so far behind in the jobs I have to do at both work and home (including car) that I have become immortal. There's simply no way that I can die now.
    • Each to their own I guess  Me, I put just as much time into cleaning inside of the cars as I do on the outside As for getting wet, it is really no different than steam cleaning the carpets at home, apart from the cars carpet dries alot faster than the house, again, I only do it in the hotter months and leave the car opened up for a few hours As I only do it yearly, it is just before I do the diff and gearbox service, so I clean the carpets, then it's up on stands, wheels off, service, clean the undercarriage,  grease the bushings and do a nut and bolt check on everything  Disclaimer: I typically had all the time in the world to kill when I was working 🤣, so spending a full day or 2 cleaning, serving and "looking at stuff" was,  easily achievable, and a fun mental therapy day As for time to kill, I retired last Wednesday, so apart from my physical training, my days are filled with lots of random jobs around the house and garden...."Idle hands are the Devils something something" I am also buying a new house sooner rather than later, I'm actually looking at a potential property tomorrow, I'm looking forward to getting a car hoist as I'm starting to get to old to crawl around under a car, I can only imagine all the undercarriage cleaning and looking at stuff when that gets set up
    • Yeah, I'm not interested in wetting the carpets, and I don't care about brown dirt/dust that lives deep in the pile or underneath. It's not like I crawl around on them in my birthday suit or eat dropped food off them (because there is never any open food in my car). The seats are alcantara (cheap Chinese imitation alcantara, to be sure!) with barely 1" of foam pad behind the surface. That's not getting wet either. Any car that I would be happy to get the interior wet, I would not care to put the effort into.
    • We have one that holds 2.8L of water. On floor carpet that hasn't been touched in 2 or 3 years, will take a minimum of 2 fills of the tank to do a bedroom, and that's going AROUND the bed.   In the cruiser, I used an ENTIRE 2.8L tank, just on the front passenger footwell. But it had some fungus growing, and had been full of mud from being used as a 4WD for many years. I can do that floor again, and it will still pull mud out. However, the water now only looks dirty, not pitch black and leaving full sludge in the bottom of the tank it sucks back into. Oh, and, this is about a $1500 unit.
    • This is mine, works a treat for the cars, suction is good, I use the Bissell clean and protect stuff I have found giving it a good spray and light scrub with the soft brush on the head of the nossle for carpet, and a rub with a microfibre for cloth seats and cloth door trims, prior to another quick spray before vacuuming it up works the best @GTSBoy You would surprised on what it gets out of carpet and seats that actually "look" clean, I recommend that you test drive yours when you have a little time to kill, then post pics of the muddy looking water that I believe you will find
