Hey guys got some cosmetic mods for the engine bay area to hopefully make it look a little better.....still have to fit them but here are some pics in the meantime
Ordered them in NOV 07 and just arrived a couple of days ago......been really hanging out for them.
ARC - Titanium Radiator Plate
Blitz - D1 Radiator Cap
Tomei - Oil Filler Cap
https://www.sau.com.au/forums/topic/205981-new-bits-for-my-r34/
...You waited over 3 months for a radiator plate, radiator cap and oil filler cap??? I thought 2 weeks was a long time :blush: .. BTW, where and how much did the Tomei Oil Filler Cap cost ya? I'm going with the Tomei theme for my engine (Tomei internals, Tomei turbo kit... and so on)
I got all the gear from Nengun.com, they send it from Japan which is why it takes a little longer. Took longer than usual for me due to them having troubles sourcing all the parts. Usually around 25 days or so.
You can get it through Nengun for $95 delivered [$76 for the cap itself], looked around and it goes for around $130 - $150 here in OZ i think you would have delivery on top of that. If you dont mind waiting you can save abit.
Thanks but I live in S.Korea so shipping doesn't take longer than 2 weeks. I just never seen a Tomei cap... always the nismo and other caps. I'll get it from my source... they have pretty good prices. Thanks for the info tho.
    • Hi all. So I have my GTR on the lift and have been working on it a few days and yesterday I unpacked the frontpipe that was wrapped with heat wrap stuff, because part of it was breaking down and soaked in oil. Noticed that the pipe itself does not actually look like a Mines, despite it supposedly being a Mines. But I could not find any fronpipe online that looks exacly like his, and I don't think it is a custom one. My amateur measurement also showed the two pipes are about equal length, so maybe this is just an old version of the Mines pipe? Would appreciate insight on this by the enlightened folks. greetings from Germany
    • Yeah. If I plug the connector in and connect the vacuum lines, I assume worse case scenario is that it simply doesn't work? Yep PFC.
    • I would think that rather than attempting to perform an engine swap, with all the difficulties associated with doing so in a country where the raw materials required are harder to get hold of, I would just build the CA20 for boost, find an EFI manifold for it and either add a turbo or a supercharger. Or both. You replace one set of difficulties with a different set, but I know which would be more fun.
    • Well, a proper aftermarket ECU** SHOULD be set up to run the purge solenoid, same as the factory ECU would, so that the tank breather system continues to operate the way it is supposed to. I have no knowledge of whether the PFC (which is what I assume you mean when you say Apexi) has an output (and internal logic) to run the purge solenoid. If it does not, then given the product design intent for the PFC, which is to be a plug in replacement for the stock ECU, I would consider that a massive failing on Apexi's behalf and would be another reason to think that they were a half-arsed solution to the problem if programmable management on RBs. I would suggest that since Nistune came to market (which is a LOOOOONG time ago now) there has been no valid argument for choosing a PFC, especially if the PFC can't do things like this.   **ie, Haltach, Link, Motec, etc
    • Thanks for asking the question we were all thinking!
