Due to an upgrade to a different setup i have for sale a RB26 head that was ported and assembled by trick flow heads having nothing spared, port work includes inlet and exhaust work and polished chambers.
Head comes complete with 1mm oversize ferrea valves both inlet and exhaust, springs and retainers and 280 deg 11.8mm lift cams. It has been modified for a oil return back to the block from the back of the head in dash 10 braided line and has been used on my own engine which made 727hp at wheels on 28psi and with only 266deg cams.
This head was done about 2000kms ago and has been fitted with new guides and stem seals.
It will suit someone looking to make big power and who doesnt want the expense of getting it done brand new.
This head cost over $7000 to do so am asking $3500 complete.
The head is still on the car and will be pulled this weekend so anyone wanting pics will have to wait till then.
Can see in person or if you want to see it run then give me a call and i will arrange it.
Will not seperate this item so do not ask price is $3500 this is very cheap seing as a bare head will cost you $1000 at least and thats before you spend another thousand on guides, seals and servicing
Contact me on 0422214621 or pm me
was that power figure before or after the head job ?
Will any manifolds & coil packs be available as well? wouldnt mind swapping my 25 head to a 26 head.
Why are you selling ?
Edited by Guilt-Toy
That was same head but different cams, the head will make more power with these cams as that is what it is setup for. The reason i am selling is i have sent a head overseas to be cnc'd and am going to start fresh with the new head as its easier than selling a bare head on its own
  • 1 month later...
  • 6 months later...
Julian both you and i know you sold this head knowing full well it had issues...in a nutshell it was rooted! You have even said so to other well trusted members of this forum at last years Summernats.
The port job is crap, the guides were not new...simply knurled stockers, the valves had too much ground off the tips and the thick 'custom' shims used on 3 of the exhaust valves were chamfered to stop them riding on the retainers, this didn't work as the retainers are badly marked from contact. The only reason you wanted to keep the cams is they were the only thing worth saving. If this head was set-up for these cams why did you want to separate them?
Id advise you to contact Simon and discuss it before he contacts you.
Please post your new mobile number so this problem can be resolved.
Thank you
Edited by DiRTgarage
This head was not assembled by me but by pro engines.
The head did make that power and had ferrea valves, performance springs and ferrea retainers.
I did not know what shims it had as i did not assemble it.
As for the guides they were brand new stock ones as i said to simon and i know this as i supplied them to greg at pro engines.
As stated to simon any problems to contact me.
I have changed my number and the new one is 0431318930.
Simon has contacted me since purchasing this about 30 times and i have always answered his questions.
The last time i spoke to Simon he had it checked by his builder and the only thing they found was that the port work was small on the inlet and it needed further work(nothing about all the other things)It has been 7mths since he purchased it so why so long to find all this.
I can't vouch for the head assy but there was a problem with the springs and they were replaced with performance springs.
The reason for sale was that i started brand new with a totally different setup not because it was faulty.
I can only take this up with greg as to why this work was done like that and see if he will fix his mistakes.
Thanks for the prompt reply...
The guides have been knurled...you would not knurl brand new guides...id be approaching Greg to find out what he has done with your new guides as they are not in this head.
In your 1st post you state "the head was ported and assembled by Trick Flow heads" this is now not the case. OK
Ill leave it to you guys to sort out this mess.
Thanks again Julian
Paul
UPDATE
Julian has been more than helpful and has agreed to buy back the head after we sort all the issues with it out (as i don't want it to be onsold to anyone until im confident its a good thing) and take it up with Greg at Pro Engines.
Thanks Julian top stuff mate.
  • 2 years later...
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
    • Remember reading about this not too long ago. been for sale for a long time  this is like when the wife says you need to sell the car so you put it up for a ridiculous price no one will pay
    • You are perhaps suggesting that it is not a super car? Well....it's not an AU.
    • Dropped the MX5 of this morning to get the hardtop colour matched and some PDR done, they are also going to give it a buff to remove some "stubborn" swirl marks and light scratches in the clear coat Over the last few months the poor little thing has copped some shopping centre car park abuse, I try to not park in them, but hitting Westfield's a few times over the last few months has taken its toll, nothing really bad, but enough of a trigger for a "while we're in there" thingie  Once it's back and all the one colour, with a few dents and mark's removed I'll give some of these products a go and see what they're like
