I'm about to drop some Smooth shift 75w-90 semi-syn in (r33 gtr box) Will let you know how it goes Also got Some Gulf Western LS90 for the front and rear diffs (its friction modified, and i read conflicting things about needing lsd oil for the stock vlsd but friction modified can be run in non lsd diffs apparently so i'm not worried)
Isn't smurfs blood bad for LSDs? Something about the friction properties?
I think the redline lightweight is for gearbox's but the heavyweight is for diff's. My mate runs heavyweight in his standard R200 VLSD and has zero issues with it *shrugs*
Had a look and because the VLSD units are sealed, you don't really need the friction modifiers
But nissan still recommends a different oil for the lsd compared to the front diffs (33gtr etc which are open)
I had Gulf Western LS90 put in the front and rear diff, seems fine
Anyone have some tips to get slightly rounded filler bolts out of the gearbox? The mechanic couldn't get it undone and didn't want to push it too far, he recommended going to a gearbox place :wacko:
I do have one tip for that....you can buy 13mm square drive plug removers. So ideally buy one of those, and once the old plug is out replace it with a new plug.
Or take it to a gearbox place :ph34r:
  • 1 month later...
  • 1 month later...
  • 1 month later...
i have a non turbo R34 GT-X 4WD, ive just hit 100,000 k's so im about to do a major service,
will Castrol Transmax Z be fine for my gearbox?
and Castrol SAF-XA for my diffs?
any anyone have an idea of how much oil i need for the 1 gearbox and 2 diffs?
thanks
  • 4 months later...
hi guys just wanna get this off my mind i'm using penrite smoothe shift 75w-90 it says its gl-5 but can use where gl-4 oil is use iv heard gl-5 isn't good for these boxed is that right ?
i hope its ok because it shifts nice and the gearbox goes better
theres a link to what im useing http://www.penriteoil.com.au/products.php?id_categ=4&id_products=380
I use heavyweight for diffs and gearbox. Gearbox is smoother and quieter. Only issues is 4th to 5th at high rpm. If I rush it it crunches a bit. The diffs I find are more efficient when warmed up...when cold they lock up a bit.
I have the exact same problem with my box but I run the lightweight. RB25DET Neo box with unknown KM's. I just shift it nice and smooth into 5th
Yeah don't know why, maybe too thick for the synchro. Is it because the 4th to 5th synchro can't engage quick enough because of the oil because they were perfect before?
Might try to drain half and put some lightweight in and see if it makes a difference. The rest of the gears are perfect though and the box is nice and quiet.
  • 3 weeks later...
Do you mean I won't be able to get all the redline oil out ?
Why can't these be mixed hmmmm
Maybe because of how well it sticks to stuff.
I had a patch of lightweight shockproof stick to my chassis rail for about 8 months before it finally wore off.
Having said that, right now I am running a mix of 75% MT90 / 25% lightweight shockproof in my gearbox without any issues.
I'm going to use Amsoil next time so will update with any problems (if any) from mixing.
hi guys
thinking of changing my Front diff, transmission, transfer case , rear diff , ATTESA for my r34 gtr vspec
what do u guys recommend and how many litre's do i need each?
front diff and rear diff- Castrol SAF-XA ?
transmission - toyota v160 2litres ?
transfer case - castrol transmaz Z or nissan automatic type d ?
attesa - ?
just want to confirm with you guys if i have the right oils and how much i need before i do it
thanks guys
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
