Folks,
The 2008 Allied Metal Recyclers Speed Event Series kicks off on Saturday arvo/evening at Wanneroo. Starts at 4.30 pm & finishes under lights at 10.30.
Spectator entry is entirely free so why not come down for a look? Say hello even. :wave:
Full details are on the website (also calendar, entry form, registration, supp regs etc etc) and there will be the usual bewildering range of cars entered. Remember this series is our only state based sprint & hillclimb competition & features everything from sports sedans, wings & slicks open wheelers, ex rally cars, road cars, historic cars - you name it you will probably find it there. Well worth a look. :blush:
www.speedeventseries.com
https://www.sau.com.au/forums/topic/205996-2008-speed-event-series/
Well done Richard, a great result, especially considering the first 4-5 are dedicated racecars :(
http://www.natsoft.com.au/cgi-bin/results....02/2008.BARB.Q1
Faaark me - the first four or five? :D I wish. Out of the first thirteen twelve of them are either race or rally cars. The other was a GT3 Porsche. :D I remember the old days when you had half a chance of a result in a road car. :)
Anyway my driving sucked badly on Saturday - so there is much truth in the rumour I couldn't drive out of sight on a dark night. Mind you, with stock brakes the thing can be seen from quite a distance. I can't even claim to have been the quickest Nissan on the night. Paul got me by 0.2 seconds. But I did manage to be the quickest Skyline. Mostly because George took his thing home on the back of a trailer after some unhappy engine noises.
It was a good day/night. Glad the 38 degree temperatures didn't eventuate.
Oh and next round is on in Collie on the 2nd March followed by the Busselton event (I think). Be nice to see some Skylines there.
Edited by djr81
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
