  • Replies 81
Yep! Both Freebaggin & myself have LT12 plug-in ECU's. We’ve had them for sometime now.
My ECU took very little time to get tuned thanks to Freebaggins map being loaded into my ECU & then tweaked to suit my upgraded turbo/fuel system (1.5hrs tuning). After one more small on-road fine tune (15mins worth) my car now runs beautifully! The power curve is smooth, even better than my previous Unichip could manage. This is mostly due to the piggyback nature of the UC. The UC can't overcome the stock ECU AFM commanded ignition retard that GTS25t's suffer once you start making decent power & the airflow maxes out the AFM.
Both Freebaggin's car & mine run new inlet set-ups as we no longer need to run AFM's.
The LT12 has a very impressive range of datalogging info. It can also be tuned via both laptop, or the optional hand controller (also acts as a display/logger). I don't currently have a HC but it's only a few hundred $. Freebaggin can give you more info on the HC as he's got one.
In my case we had to run an extra wire to get everything up & running, it also took a bit of time to iron out a few bugs with the "LT12 to stock loom" adapter plug, so it wasn't a quite as simple as a PFC. But Freebaggin’s car & then my car were the first to have the new LT12 GTS25t Microtech fitted so it was still in the trial stage (in fact the photos in HPI are of my engine bay & Freebaggins inlet set-up).
The LT12 ECU's are now fully sorted & offer a true local plug-in option that's somewhat cheaper than "most" other options.
Since the fine tuning work my car has no problems with cold starts, idles fine, drives perfect, has zero problems with a vent to atmo’ BOV, & thanks to a few other mod’s makes 236rwkw on 14psi. It can even give the odd slightly modified GT-R a run for it’s money :(
I’m sure Freebaggin will be able to add more valueable info but if there’s any specific questions then ask away :)
Matt.
Whatisname, I think you've covered most it.
I think with all the half reasonable prog ECU systems on offer, the WOT peak power and power curve that can be gained would all be within the same ballpark, from Microtech to Motec M800. The piggyback options are less successful for this I think.
However it's the other nice things that then make a difference like purchase cost, installation ease (cost), fuel consumption, part throttle drivability, idle quality, upgradability etc. It becomes a compromise.
Here is what I think the advantages and disadvantages of the plug-in Microtech are.
Adv.
*Low cost
*Laptop tunable and data logging
*Plugin (except for air temp sensor install)
*No AFM
*Very cheap hand controller (~$150-160) that also datalogs to a point and indicates all the major functions
*Pretty attractive Dash display including shift light and also most hand controller functions ($500)
*High degree of upgrade flexibility (extra injectors, NOS, boost controller, injectors of any resistance OK etc all controlled from one ECU)
*Potential of system not fully realised with software upgrades on the way for increased tunability as well as modular additions
Disadv.
*Increase in fuel consumption (non closed loop may be contributing to this)
*Load and set point number lower that most other ECUs
*I still have some flat spots that are difficult to tune out so still more tweaking required (however Whatisname has little or no probs)
Anyway, I'm very happy. But the main thing, is that I have only started and I'm looking forward to a trouble free power upgrade path due the Microtech flexibility and also the contstant upgrades that are in the wind for the LT-12.
Cheers,
Freebaggin.
Good stuff Lachlan! I knew you'd jump in with some excellent info :)
A few quick things to mention with 2 of the disadvantages Freebaggin mentioned.
*Fuel consumption - I did a cruise with the local Adelaide SA guys recently, afterwards we were talking about fuel usage, it turned out that I hadn't used much more than a fellow GTS25t owner on the cruise, his car makes less power & still uses the stock ECU. I’ll admit my economy isn't quite as good as when I had the UC fitted, but the power/driveability have both improved.
*Flat spots/general driveability - Like Freebaggin pointed out, I've been really happy with the driveability of the car since getting some on-road tuning done, & I've never experienced any flat spots.
INASNT,
Some of the reasons I did not pursue the Power FC:
*No data logging available at present
*Non laptop programmable at present
*Injector type limited to factory resistor specs (expensive items usually)
*Not possible to control extra fuel injectors, water injection or NOS from ECU
*AFM still required at present
*Load and set point number only marginally better 20/20 I think compared 16/16.
*Expensive
*Boost controller expensive
*Hand controller expensive
*Limited local Apexi support
etc
So eventually Tim at RPM and I decided to see if a plug-in Microtech could be developed and here we are.
Please correct me with any points, but they were some of the issues I had with the Power FC when I was deciding what ECU to get. However as you say some of those issues may change over time with for eg. English software may become available etc.
Quote Freebaggin:
I was under the impression that the Microtech L12 was closed loop.
Well thats what Tim told me or is for some reason yours isn't running closed loop? :)
Meggala if the AF's were all in order wouldn't the emissions be in order also?!?!
Or is there more to it other than just not running rich or lean?
*whatsisname*
I have his UC..
economywise, gain around 15-25kms more as I get around 230km to 1/2 tank.
power/driveability/fuel consumption hampered a bit by atmo BOV but otherwise an excellent budget upgrade.
Hi Nath :(
Yep agree with you on the UC mate, it's a very good unit. It's "spot on" with fuel consumption & driveability. If only the damn factory ECU ignition timing retard didn't start rearing it's ugly head once power gets over ~220-230rwkw :O
The UC driveability only declined when the stock ECU started to play silly buggers with timing.
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
    • Hmm. I've gotten pretty good outcomes from talking to them about things that I've had go wrong or ideas for improvement. Have had a lot to say about the R32 FUCAs, and they have sent out some replacement parts for those, gratis, on a couple of occasions. Mind you, I have bought a couple hundreds of $ of replacement rod ends for them too!
    • I have a r34 sedan 1999 manual converted need some help with my speedometer it only reads upto 98km and then stops currently still running the auto cluster any easy fixes no speedo drive is connected yet, if someone has a video for wiring up the manual speedo sensor with the auto cluster please send through
