Hey guys I've been toying with the idea for quite some time but have never really done any research on it. Basically it’s MIRC and i know most of you have used it with the exception that you don’t have to load anything into your computer. I’ve found a free online java client so all you will have to do is go to the webpage put in your username and type in your server and channel. And it will connect and you can all talk in the main channel called #SAU or you can private chat 1 on 1 so that no one else can see what you are saying. The only advantage on this is that ever one who is logged in will receive your message as it is sent so organizing meets or selling parts can be done quite simply.
to do this you need to go to this webpage (anybody that has firefox loaded in thier PC will have to use FireFox not internet explorer):
http://irc.netsplit.de/webchat/?net=AustNet
and in the section where it asks for "chat room" type in #SAU, make sure you type in the #
next line is "Nickname" anything you wish to call yourself.
and then click "start web applet"
it will take a few minutes for JAVA to load up and might even give you a warning about something or other just click yes.
and then should give you the client screen with the word "connecting"
now if it doesn't connect and you receive "Unable to connect : java.net.ConnectException : Connection timed out: connect "
just below that is where you type all your text type this "/server ezehost.il.us.austnet.org" hit enter and it should connect to Austnet and then #SAU and you will be
able to say anything you want in the main channel. or if you double click the names on the left you can private chat to any one else you choose.
This is a great way to chat in real time to other SAU members
Send me a Message if you are having any trouble connecting to the Server and ill do my best to help out. Some of you maynot be able to connectas your firewalls at work may not allow you to view the page but this can be fixed using a Proxy like www.blastproxy.com
Edited by loymclure
https://www.sau.com.au/forums/topic/206007-sau-chat/
Well I'm connected to Austnet but can't figure out how to then head into the SAU channel? None of the buttons are working either.
NVM, went back to the tab after writing that and it worked. *shrug*
Edited by MIVEC
https://www.sau.com.au/forums/topic/206007-sau-chat/#findComment-3645334
hey guys and gals if you do log on and you like it let me know on this thread so other people can read what you have to say about this chat program. its very easy to use and best of all it can be done from work lol...
Edited by loymclure
https://www.sau.com.au/forums/topic/206007-sau-chat/#findComment-3645336
this is really good considering there can be upto 300+ people online and get them in a room especially good for a quick meet say on a friday nigght maybe there is nothing planned but a few people in the chat wouldnt mind a cruise so they organise it there and off they go, no need to waste a forum post on a small cruise
https://www.sau.com.au/forums/topic/206007-sau-chat/#findComment-3646318
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
