  • Replies 64
  • 3 weeks later...
anyone know the whereabouts of this young ladie?
the young lad is in singapore at the moment and will be in the philippines by lunch time. again 3rd time in 3 months.. i work in manila for GMA7 which is channel 7 for the local TV
He went to the Philippians for a sex change, having a penis and looking like a female was becoming to frustrating for him.
Pretty sure the he-she said he was back next month when I spoke with him
yeah i was back for a week then away for another month..
as for sex change... not likely i like having a penis and being a pretty boy.. its wats makes me my moolah.. better than looking like a hot emo.
btw josh im wearing a tight lonsdale jacket ull dig it.. tight cause i cant pull the sleeves up :blink:
He had a forced break from SAU (one week i think) and never came back...
He still uses PM's and he is online regularlly, he just does not post anymore...
havent logged in in 3 months to see what would happen. and i now determined that sau went to shits. ya'll a bunch of wankers and noel should die.. :D haha... seriously it died.. and i ahvent replied to any PMs and wont till june when i get back to australia.
ill pop in every once in a while ;)
btw josh im wearing a tight lonsdale jacket ull dig it.. tight cause i cant pull the sleeves up :P
ill pop in every once in a while :)
funckorf
Yeah i went and saw mark last night and hung for a bit... he says everything is going good over there and will be back early to mid june....
Oh and yeah about the sex change surprisingly he looks more like a guy now than before he left he actually has a proper hair cut now lol.....
Edited by redevil
So thats what he over there selling on infomercials nasal spray.....GMA7 must stand for good morning australiasia 7!
pfft.. heard of star magazine asia... if u get a chance have a look through the april edition.. :D
GMA im not sure what it stands for but 7 is the channel number...
u wanna knw who i get to work with :)..
look up sex bomb dancers and daisy siete its on wikipedia :(
anyway im tierd had a press release for a daytime series this arvo and im sore from smiling.. :D
pfft.. heard of star magazine asia... if u get a chance have a look through the april edition.. :thumbsup:
u wanna knw who i get to work with :D..
look up sex bomb dancers and daisy siete its on wikipedia :)
anyway im tired had a press release for a daytime series this arvo and im sore from smiling.. :D
so u work for a gossip magazine i take it. cool. least you get to go all over the place i guess.
im on the cover of star magazine dude..
i studied..
2yr mechanics.
2yr accounts clerk/law
do actually google sex bomb dancers terry ull like what u see.
daisy siete is a cheesy drama like neighbours. technology here is better so the effects are state of the art and above australias par. so the trailer and opening sequence was conjured with a pictorial and 1 shoot. its cool should be on youtube.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
