this is what i did. maybe not as pretty as the apexi kit but does the job.
I tell ya wot mate, Wot u have there looks pretty dam good to me and id say at least half the price! good work, definatly doing the same thing, I like
look at the pictures.....
Look into my eyes, look into my eyes, look into my eyes..... :D
Yes the pretty picture shows a diversion plate. But also a pair of Apexi pod filters linked to some 80mm Z32 AFM's (Actually Bosch units) using the Apexi kit. And there is also a www address to greenline.
Daaem thats cheap! To think I've been looking on jap import sites like a sucker :D
The new improved apexi kits at half price hahah! I recon wot old mate has looks pretty plush and CHEAP I worked it out I can get 2 x apexi pods, 3inch 90 & 40 degree bends + 2 x silicon hose and clamps for $220 everything brand new, or you can get the apexi kit for say $500-700 depending on some websites......I kno wot ill be doing
Don't forget you need the plugs to go into the AFM's. They come with the Apexi kit but not with the Ebay special.
Edited by djr81
The poor man's solution;
I stretched the standard rubber hose over the 80 mm AFMs, 65 mm to 80 mm so 7.5 mm was no big deal. I bought a couple of new hose clamps as the standard ones were just a bit too small.
When I bought the AFMs (SAU "For Sale" section) I made sure that they came with plugs.
I already had one HKS 80 mm pod filter off the R32GSTS, so I bought another one from the SAU "For Sale" section.
All up cost including the AFM's was $650.
Cheers
Gary
Cheers
Gary
i also tried that but found the front filter to stick up in the air and could not shut the bonnet due to not clearing the blow off valve return pipes. that was with the apexi filters which are longer though.
Cheers
Gary
Id have to say I did a bit better then u sydneykid $220 for the apexi pods, bends, silicon hose and clamps + $150 for 2 x rb25det AFM's + bonus of not having to have plugs as they straight back in to the rb26 so for me $370 total including afm's
or you could just buy 2 rb20/25det afms instead of the Z32's then u dont need plugs! ebay special wins again hahah
Except the RB20 AFM's are not nearly as good as they are made out to be, nor as good as the Z32 units.
Edited by djr81
you need to lengthen the wires for the plugs though. I was only after around the 350awkw mark so thats why i used RB20/25 afm's. only cost 70 each and the car makes pretty much 350awkw. they are getting close to readig 5 volts though.
Edited by OFENSV
Before spending 80bux on two plugs, can one use some small female spade terminals to attach to the AFM?? I'm giving that a go before departing cash for the real thing.
Edited by GeeTR
LoL, come on, what I look like?....
wait, don't answer that :ninja:
Correct position and some wide rubber / polyurethane tube around the AFM plug, to stop any moisture / dust getting in there. I'm not quiet sure why ppl buy the plug. Guess ill find out soon. Will do a DIY too.
Edited by GeeTR
Crimping the spade terminal a lil should grip the pins ok, then maybe large size heat shrink over the whole lot, zip tie? or afore mentioned rubber tubing?... maybe it is a too ghetto :huh:
There would have to be a more elegant solution, giving some time thinking.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
