Hi ppl,
I have a 33 GTST series 1.
Full exhaust, split dump then 3.5" from there back.
Splitfires
Apexi pod
FMIC
A autobahn88 silicone intake from pod to turbo.
Also running no BOV
plugs have done 9 thousand kays
got home from work, car was warm, and was running great.
Just fitted My PFC, I hit the ignition, set the boost kit to off ( to the little japo symbol that looks like a plus sign) started it, ran like shit, after 10 mins I hit the AC, then after 20 mins I turned on the demister, after 30 mins I let it run for a further 2 mins, shut car off, started it again, hit the throttle a tad, say to 2000 RPM and sounds like its running on 4 cylinders.
any ideas or input will be greatly appreciated
cheers
Edited by Mr. Untouchable
hi paul, thanks for the reply.
I checked the sensors, nothing was highlighted.
what to you mean version?
on the rb25det screen it comes up,
PowerFC
Ver 5.11
FC Commander3
Ver 5.01a
jsut checking - to be sure, to be sure
put the stock ECU back in - confirm it runs Ok and isnt mssing/ running on 4 cyclders
then if its OK and stable etc open up the FC look for burnt tracks or damaged components
is the FC new or used ? did you do factory DATA INIT before starting the car ?
i bought it brand new from access autoworks.
what do you mean factory data INIT? all i did was turn the boost control kit off and then turned the key and did the 30 minute idle set with , 10 mins of idle, another 10 with A/C on then the last 10 with demister on?
Had similar problem with mine, pluged in the power Fc and ran 4 cyc, put the factory ecu back in, ran on 6.
Put power Fc back in and realised the factory plug on the wiring loom gets a curve in it if the bolt is over tightened.
Either loosen the bolt or put cable ties around the plug and power Fc to pull the ends in tight. Ran perfect after that.
arrhh really?
mmm okay. will try that next..
will give that ago in the morning
well just put the FC back in, made sure the plug was in properly and it ran on all 6. brilliant!
awesome thanks for the advice guys.
I guess I might have to do the 30 minute idle set again??
