  • Replies 45
Posted Images
^^ lol true that ...
stock is the best bet for passing emissions ... plus using the cat that cam with your car originally will help a great deal.
when an import is complied they usually put one crazy restrictive cat in to help with noise and emissions
was pulled ova last night.
saw the coppa go past me, and chuck a u-turn at a set of traffic lights. u-turn was NOT permitted (illegal)...but it was a coppa so what can i say.
"excuse me sir this is a random breath test and rego check, licence pleasse"
then again, i was running the gauntlent at 330am in the morning :S
  • 3 weeks later...
Test should only be noise, try asking a compliance workshop thats been around for a while (eg. 60kph constant speed past sensor 3 meters away). Mid muffler is a good idea.
Pollution only goes as far as to check for a cat converter. An enclosed pod is absolutely fine for sure, though you could present evidence that the car was complied with the pod the way it is, chat with the people that complied the car originally if you can. Depending on the import/manufacture/compliance date it may have different compliance rules regarding pod filters. A cold air induction box with a coupple of pipes bringing air to the box will improve efficiency and is therefore a good idea though.
The cops don't know what mods are legal because different laws apply to different Australian manufacture/compliance dates on the same model car with the same production date in Japan.
Apparently you get a fine and then you get it cleared, not sure if you still have to pay the fine if it was complying in the first place?
Let us know how this goes, do they charge to do the testing, when I asked workshop they told me it costs about $3,500 to get the testing done and compliance certificate for mods?
    • https://www.efisolutions.com.au/coolant-temperature-sensor-bosch-180sx-s14-s15-r33?gad_source=1&gclid=CjwKCAjwzMi_BhACEiwAX4YZUHsCQhbiDT_NC3q5wD9jrzH6Dts9eGSr19NXSDw7x9WVm1sH7G3S4hoCwaUQAvD_BwE this is the one i replaced today
    • I have replaced the larger coolant temp sensor, i do see a smaller one next to it (looks to be just 1 pin) but i assume that is just for the dash? or should i replace that aswell?
    • Check coolant temp sensor ~ symptoms fit the hard hot start/cold start OK scenario --- if sensor goes open circuit, ECU thinks engine is cold and enriches mixture ....works when engine cold, but floods them with rich mixture when hot (Hyundi MAP engines are a bit infamous for this)...
    • OK, starter changed for a spare without much trouble. Neil had kindly left space to get to the top starter motor bolt from above with a long spanner which makes the whole deal much easier, and everything else was neat and easy to get at from underneath. Once the starter was changed everything was good, unplugged the CAS and turned the motor on the starter to make sure everything was free and happy. Onto properly priming the oil and first start. I'd picked up one of these oil prime kit from Boost doc a while back and this was my first time using it.  https://boostdoc.com.au/products/engine-oil-prime-kit?_pos=1&_sid=28c628a65&_ss=r While I'd organised all the fittings to hook it up to my GTR (sump plug to -6 feed and -4 T to tap it in and retain the oil pressure gauge, neither suited on this car as the oil pressure needs to T into 1/8 NPT not -4 and the Aeropro sump has some massive drainplug not that factory whatever it is. So, waiting for a couple of fittings, then I'll prime it and do first start, hopefully next weekend. Other than that going well, there is very little stopping a final alignment, tune then shakedown day
    • Also to mention, i just tested the CAS, seems to be working fine, can hear the pulses inbetween 0 and 180 degrees, another mention aswell, when i let the car sit for about a hour today, i went to start it and it almost fired on first crank, then just completely struggled. Could it possibly be blocked injectors?, maybe allowing a little bit of fuel to seep past allowing it it almost start first crank?
