I know you are new to the site, but use the search button
The part number your after is 48520-23U26
Left and right the same
Approx $70-80each
If nissan Australia does not have stock, 2 week wait from Japan
https://www.sau.com.au/forums/topic/206154-tie-rod-ends/#findComment-3648217
Approx $70-80each
Thanks for the information and advice
https://www.sau.com.au/forums/topic/206154-tie-rod-ends/#findComment-3648924
Paul the local nissan dealer is great when you need parts. The girl there in the parts department knows her stuff, she'll find you anything you need to know.
For anything suspension wise, I'd recommend going up to WA Suspension in Ossy Park, R_Dirty_3 on the forums here works there so any questions, aim them his way :ninja:
And there is a 'workshop' thread in the WA section on these forums for places that have been recommended by skyline owners.
https://www.sau.com.au/forums/topic/206154-tie-rod-ends/#findComment-3649615
It is very likely you can get local alternatives too. I know they are available for 32 gtr and 33 gtst about 1/3 the price of nissan.
BTW I found in both cars I looked at that it is the inner part of the tie rod that wears (nylon joint) not the outer ball joint. So you might want to consider doing both inner and outer
https://www.sau.com.au/forums/topic/206154-tie-rod-ends/#findComment-3650218
  • 10 months later...
Approx $70-80each
Thanks for this info! I was rotating my tires last weekend and found my left wheel wobbling - Tie-rod end badly worn (don't know how it got a road worthy!) Jumped on the forum and after a bit of reading, decided to go genuine (read the story about taper diameters and lengths being different on alternatives). Called the local Nissan dealer and gave them the part # above. They called back 2 hours later and said they have it ready to pickup! I was expecting a 2 week wait and got a 2 hour wait instead! I am blown away by Nissan's support for a model that was never even sold here.
It cost $93. Out of interest, I also called Nissan parts in Japan - same part from Nissan Japan is 6300yen - which converted to almost exactly $93 on that day - coincidence?? :cool:
https://www.sau.com.au/forums/topic/206154-tie-rod-ends/#findComment-4358181
    • I've sent JaseR33 a private message in the hope he gets an email and contacts you
    • I have seen a case where the starter motor shorting against the casing caused a massive voltage drop + so much EMI that it caused all the sensors to spew garbage data at the ECU. Test the battery to make sure it has acceptable CCA/capacity first, I have gotten "brand new" batteries before that couldn't even power a 10W light bulb without dying probably because it sat in a warehouse too long without being charged. Only easy way to diagnose this 100% is put an oscilloscope on the battery and also look at key sensors to see if there's any clues.
    • There's a bunch of smaller shops that don't quite attract Singer money but are still hiring from that same pool of labor. Those are the body shops that you go to when you can't afford a Singer, but your old Porsche needs some serious bodywork. You can't exactly take those cars to the usual insurance body shops. When I say restomod, I mean they'll do something other than 100% OEM/OEM-equivalent aftermarket parts R&R. In the Porsche world this would be stuff like taking a 50k 964, doing a bunch of deferred maintenance/unwinding the nightmares the previous owners did to the car because a lot of people that own these cars tended to be penny wise, pound foolish types, then maybe some relatively simple off the shelf modifications to things like suspension, transmission, engine, headlights, etc. and you've spent 130k USD. When even the worst houses in the poor neighborhoods are worth 1M USD and the nice houses in wealthy neighborhoods are worth 3-10M USD suddenly 130k spent on a 50k car seems cheap.
    • Hoping to get a few ideas to help troubleshoot this issue, I'll try to keep it short.  A mate popped the motor in his 2018 LDV T60 with the 2.8 turbo diesel motor. He swapped it and I was his phone a friend when he got stuck.  The new motor is in, however it won't fire. The battery is literally brand new, when you crank it the volts very quickly (say 2 seconds of cranking) drop to 8 volts and the engine stops turning over. Watching the belts, I'd say they move about 5cm before coming to a stop. We put a booster pack on, no change.  The only potential issue I'm aware of is, when we pulled the motor the grounding strap was still attached. The strap copped a thrashing before we realised what was going on. It looks okay-ish but it's going to be replaced to rule it out.  The main challenge is, I wasn't there for 90% of the work. This is his first time doing any major work on a car and he was learning as he was going. He thinks everything has been put back together properly, however I'm not entirely confident that this is the case.  It would be good to get some ideas about what else to check. The car isn't spitting any codes so that doesn't help.  I've attached a photo, because why not lol.
    • I mean an N1 came with a minimal paint thickness compared to dealer models. It’s probably had a ton of vinyls and stuff possible a race paintjob or two over the years. you don’t buy an N1 for its stunning good looks or comfort 🤣 you buy it to send it and measure how much air you can get on the hill at Bathurst
