Anybody know what cars the R33 shares the tie rod with? Does it share a common part with other Nissans such as the S14/S15, Maxima or something like that does anybody know?
General fact of the day: For those that aren't familiar, its basically the rod that controls the toe in/out of each wheel from the power steering and goes to the back of the disc on each wheel. If you're having massive problems with your car pulling to the right or left and its not alignment, could be that is bent (like mine). Commonly destroyed when running over a gutter, or some old bitch who should never be driving at that age at that time of night running into you :)
Mine is bent :) and either needs replacing or straightening. I know places will go "oh its an import don't know the part" .. so if i can track down a part might make it easier.
How hard is it to take off?
https://www.sau.com.au/forums/topic/20616-tie-rod-for-r33/
This is front end but i assume its fairly similar.. Did look rather easy, and i thought you should just be able to unbolt it and replace with another one.. wanted it driveable at that point, so didn't start unbolting myself. But cheers, will help!
How much did the whole HICAS rack end up costing you from the wreckers?
https://www.sau.com.au/forums/topic/20616-tie-rod-for-r33/#findComment-432482
I got the hicas rack from skyline33 for $250 from memory but usually they are more than this.
Yeah i should have realised you were talking about the front end because u mentioned power steering in your frist post...oh well.
Hows your car? any panel damage or is it just the tie rod?
https://www.sau.com.au/forums/topic/20616-tie-rod-for-r33/#findComment-432504
  • 3 weeks later...
  • 3 months later...
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
