Anybody know what cars the R33 shares the tie rod with? Does it share a common part with other Nissans such as the S14/S15, Maxima or something like that does anybody know?
General fact of the day: For those that aren't familiar, its basically the rod that controls the toe in/out of each wheel from the power steering and goes to the back of the disc on each wheel. If you're having massive problems with your car pulling to the right or left and its not alignment, could be that is bent (like mine). Commonly destroyed when running over a gutter, or some old bitch who should never be driving at that age at that time of night running into you :)
Mine is bent :) and either needs replacing or straightening. I know places will go "oh its an import don't know the part" .. so if i can track down a part might make it easier.
How hard is it to take off?
https://www.sau.com.au/forums/topic/20616-tie-rod-for-r33/
This is front end but i assume its fairly similar.. Did look rather easy, and i thought you should just be able to unbolt it and replace with another one.. wanted it driveable at that point, so didn't start unbolting myself. But cheers, will help!
How much did the whole HICAS rack end up costing you from the wreckers?
https://www.sau.com.au/forums/topic/20616-tie-rod-for-r33/#findComment-432482
I got the hicas rack from skyline33 for $250 from memory but usually they are more than this.
Yeah i should have realised you were talking about the front end because u mentioned power steering in your frist post...oh well.
Hows your car? any panel damage or is it just the tie rod?
https://www.sau.com.au/forums/topic/20616-tie-rod-for-r33/#findComment-432504
  • 3 weeks later...
  • 3 months later...
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
