Hey All,
My car (r34 (GTT) was de-badged last night, the two side GT badges where taken.
I was wondering where I am able to get replacements, done a bit of a search through websites and ebay etc, and have had no luck.
I guess you could get them through Nissan maybe?
Thanks in advance
https://www.sau.com.au/forums/topic/206198-gt-badges-where-from/
Hey All,
Thanks in advance
Check these sites and choose your color/style. They have R32, 33 and 34 styles on the japanese yahoo auctions... it's just a matter of searching through hundreds of pages to find it if you can't read/type japanese.
http://page13.auctions.yahoo.co.jp/jp/auction/r40920990
http://page14.auctions.yahoo.co.jp/jp/auction/s85863326
You should ask slidewize since they have some sort of connection with the japanese yahoo auction.
http://www.skylinesaustralia.com/forums/R3...pan-t76361.html
If there's no luck there, you can contact www.rhdjapan.com and ask them. They'll help you out for sure but slidewize is local for you I think.
I'm after a set of blue badges myself.
Edited by chak8080
Easiest place to find them is your local nissan dealer with a parts department,
They can find the part you're after if you give them your Japanese VIN # on your car
usually next day delivery to them if the parts are in stock in melbourne (I'm in sydney)
expect to pay much more than they're worth though :ninja:
Edited by Yo-Yo
Thanks for the help guys & girls, I called a number of wreckers with no luck, however a mate knows a mate :teehee: that works at Duncan Nissan so he is going to check it out for me
Its amazing how just a missing little badge can ruin the whole look of a car :sweat: , just does not look right, thieving little bastards
Edited by cargle
    • Haha thanks everyone, I'll take everyone's suggestions into consideration. If I do eventually choose a car ill post it here update on the mods I do.
    • I found the ingredients at larger amounts from a Coffee Shop. 1kg Citric Acid for €8.50 500g Baking Soda for €2.50 I tried it out tonight distilled water (I got from my ACs) and dish soap. It does get bubbly with dish soap. In just two hours the hanger has improved significantly and rubbing against any remaining rust seems to flake it off. I'm going to leave it a little bit longer and see how it goes. I have read that someone even used this solution in an ultrasonic cleaner to clean a seized water pump which brought it back to life.
    • If you like more modern stuff than the R series, you should check out a V37 400R, they are pretty mod friendly
    • Haha luckily we don't have emissions, inspections, or any laws against power adders here. They only thing they somewhat keep an eye out for are ridiculously loud exhausts.
    • Just wanted to pop in an update on my setup. The CD swap has been great, I love the mazworks housing for the overall simplicity. I ended up sealing my trans tunnel with a thin sheet of aluminum reused some of the holes on the trans tunnel, and laid some window sealing EPS foam around the edges. Works great, really quieted things down and sealed up the car.  As for the power comment. Right now I am also running about 650whp. with the way the bell housing is attached to the face of the transmission I have zero doubts it would be fine, mainly because the input shaft and main shaft bearings are seated into the bell housing adapter. This means the load is NOT on the bolts to maintain the power, rather into he casing of the bell housing; Yes the bolts are doing some work there, but with both shafts locked in zero worries.  End of the day, the Mazworks solution is the easiest and safest. no need to take your trans to a shop to get milled perfectly, it fits with minimal clearancing, and you can use all your existing clutch and flywheel.  Driving wise the CD has been great compared to the big box, I'll probably swap my final drive at some point. The serial 9 shifter is gooooood, my only qualm is how tight it is, it takes a fair bit to get use to, 5th and 6th are a bit eh/hard to find at times, but maybe I need re-adjusting, and I think my clutch master is very tired and needs a rebuild.
