Not sure where i am going for compliance - i was going to ask for recommendations on who did some of yours. If you know of anyone who will do a good job that would be excellent if you could let me know.
Ryan i ended up getting the car for just under 1.5mil.
Its big and black and fast and oh how well will it HANDLE omg.... coilovers and brembos... i wonder what width tyre i can run under it.
FIRST MODS - clear front and side indicators! orange on black looks so bad... Then a decent, flowing cat-back exhaust.
you have NO IDEA how excitied i am... Actually, you probably do!
Looks nice dude, i finally got mine on the road last week and I am very happy with it, mine was stock but I am starting to get a list of stuff together. Good luck with it all, i saw your in Queensland i can recommend somewhere in Sydney???????
Edited by cefiro
I would be booking in a workshop ASAP before it gets on the boat. I used IAMSHE on the Gold Coast for my Stagea......They were ok but had a couple of small dramas with some of their work that they'd done on the car. Nevertheless car was quick through the shop and on the road as promised.
:laugh:
IAMSHE are doing mine, Heard the pretty good, quick and do a OK job. When it finally gets there. Still waiting on panel beater then goes to the mechanic. And yeah the wait is absolutley killing me. I baught a bomb of a crapadore to drive whilst im waiting and im f#@king over it. LOL
Wheres the fast foward button??
Vote IAMSHE
Looks good, first upgrade series 2 tail lights
Has it been resprayed, series 1 never came out in black from factory?
Must be a fairly good job being grade 4
Pretty sure you could get the 260RS in black S1, but not RSfour etc. Ive seen a fair few black S1 260RS's while we were searching for this one, but none in as good a condition.
If so own one of a few original black, 5spd manual S1's haha...
Might give IAMSHE a call. Anyone got contact details....??
I might get S2 taillights, but will probably just tint the indicators on the factory ones - to suit the dark paint.
Got 50 photos of the car sent to me - will post up after work.
PICS UP in first post!
Looks awesome! Engine bay looks pretty clean, can't see any paint missing off plenum chamber... maybe a few specks... might be genuine k's
Soooo, I get first guess at the 'mystery box'... Damper adjustment?
or maybe a toll counter for the toll roads? My RS Four's got one (says "Toyota" on there lol)
Is genuine k's. The interior of the car has no wear and tear at all (ie steering wheel, seats, gear shifter and handbrake, carpet, all like new) Plus has full service records etc.
Might be a damper adjustment for the coilovers... not sure.
congrats on the new purchase matey.
the "mystery box" is a PIVOT SPEED METER, you can just make it out if you look hard enough in the right hand lower corner of its screen.
essentially it is a fuel cut defender with a few other nifty functions such as, highest achieved speed for that drive session as well as 100,200,300 and 400 metre times if you want to set it up for runs down the strip, it also does an average speed as well as real time accurate speed display on the screen, which according to the dyno is closer to actual road speed than the OEM speedo, and couple of other things too.
i have one in my S2 and its a nifty little gadget that scared the bejeebus out of my old man when he took it for a spin on our private test strip, he was concentrating on the factory speedo and when it ran out i told him to look down at the other one mounted on top of the column.
he immediately buttoned off as he thought we were doin 180 but were doing 245 on the little box with 1500rpm to go till hit the red.
Oh excellent!
Thats pretty scary but ok! And this was in an RSFour-S - the 5 speed manual... Definately looking for to stretching the cars legs!
    • I have an old R32 in the shed that hasnt moved much in the last few years and probably should see the light of day. At one point I had a Nismo 1.5 centre put in the rear diff. It is a clunky nightmare POS of a thing on a good day. To make it less painful the initial torque setting has been put on the minimum (7.0kgf-m, mid is 9.5, high is 14) and the oil changed out to something more slippery. But it is still awful and ruins the vibe of the thing. So my questions are: Given I have the original parts sitting in a box somewhere would it be better to rebuild the thing again, reverting to more purity? Is there a standard kit or do you just go and replace the friction plates etc and shim it the way you like it. How much initial torque does the standard R32 rear diff have? Or does the Nismo disc kit offer a better solution - the caveat being the initial torque for both options appears to be higher than the clunky 1.5 way. There appear to be two Nismo disc kits: 3843S-RS520 for 8kgf-m. 3843S-RS521 for 12kgf-m.
    • It is not a dual mass flywheel, so you will get some gear noise on a BNR34 unless you deviate from the OEM fluid spec and run a thick gear oil like what Nismo recommended for a while. Unfortunately I have never weighed the flywheel by itself prior to installation but it is not that light. It's probably an 8-9 kg flywheel. OEM BNR34 dual mass flywheel is like 14 kg which is kind of hilariously heavy.
    • Got around to installing the Tomei Cam Cap Studs and the Hypertune cam baffles/splash guards. Unfortunately, I was not aware that the cam cap studs do not clear the stock RB25 internal cam cover baffles. Some research found a set from boostdoc which includes a replacement cam cover baffle and full length cam baffle + tools and fasteners. but I'm not keen on re-buying what I have already bought. So the plan is to take the hard route and modify the existing cam cover baffles to clear both the cam cap studs and the hypertune cam baffle plate. I assume there must be people who have gone through this even just to convert from cam cap bolts to cam cap studs? If so any tips would be appreciated. Otherwise I think I will mark where the cam cap studs foul, drill clearance holes in the cam cover baffle, and remove the cam cover baffle oil returns to clear the  hypertune baffle plate. I will also need to remove the baffle and drill and tap threads to bolt it back on so i can clean out any swarf. Fuel tank foam as extra cam cover baffling?
    • The incoming weather event seems to be affecting people in weird ways....🤣 And no, whilst there is some fancy engineering going on, I have no real interest in anything rotary really I had a Capella in the 90's, the rotary engine is way to temperamental, and extremely thirsty for my liking  If I won lotto and wanted to waste a ton of cash, a boosted K-swap would be what I would look at, until then, the N/A MZR2.5 will be at home in the engine bay of the NC A build like this, just without the idiotic street pulls and skids would be interesting to waste a huge amount of money on https://youtu.be/EgqAoVtUD1E?si=n3_umivrUPP8C9Cs
    • Now we're getting somewhere. All we need is a fractional rotor system so we can also have the RX3 and 5 back, and the world will be right again.
