Looking at upgrading the turbos on my RB26
The 3 that im currently looking at are the HKS 2530, HKS GT-RS, Trust T517z and Trust T618z
Just wondering if anyone could help me choose between the 4 of them!
Im after MAX. power possible without loosing too much response
Orginally i was going to use a T04z but had decided to use "bolt on" upgrades to stay as stealth as possible
Cheers
James
https://www.sau.com.au/forums/topic/206230-hks-vs-trust/
thats 4 turbos.. so u want max power with good response??? last time i seen a T517Z dyno was a few weeks ago.. 350awkw @ 1.5BAR... with.. and i hate to say this, better response than the HKS 2530 :ninja:
Im a big HKS fan.. and i dont really like Trust much.. but.. theyre small bolt ons seem to eclipse the hks variety every time :(
https://www.sau.com.au/forums/topic/206230-hks-vs-trust/#findComment-3649602
I like both HKS and TRUST
STAY AWAY FROM T618Z they are for 280 degree cammed monsters, ive used them and they are not street friendly. (think 2540 but bigger)
Go T517Z 8cm's or GT2530's.... i prefer the T517z's over GT-RS as they are a bit too laggy.
we used T517z's on the below engine (totaly std int) to make 312rwkw at 15psi and 350 at 18psi. if you prefer the 10cm versions then you are in GT-RS lag city but will easily crack over 400awkw
https://www.sau.com.au/forums/topic/206230-hks-vs-trust/#findComment-3649695
618's are the biggest bolt on from memory, 450rwkw+
Seriously though, all the questions your asking have been debated over and over again.
You really need to read the info and workout what you want.
People can only re-post findings so many times...
https://www.sau.com.au/forums/topic/206230-hks-vs-trust/#findComment-3649996
i would be going the 2530's, check out what other people have made http://www.skylinesaustralia.com/forums/Rb...yno-t93880.html .and make a decision based on that mate.
Edited by HKS_R34
https://www.sau.com.au/forums/topic/206230-hks-vs-trust/#findComment-3650161
I was wanting to use GT-RS turbines on my GT-R, but it seems there isnt much of a following for these. As i was told they were designed specificly for the RB26 to good response and mox power!
now can some one tell me a turbo that will make 400rwkw's with the same type of response as these and are cheaper at all!!! if i can get these for $3,500 im not paying a cent more for anything inferior to these!
https://www.sau.com.au/forums/topic/206230-hks-vs-trust/#findComment-3650365
9krpm : what were the response of the T517z like on your car? was your car the black GTR that was giving that white exa a run(from what the exa owner says) from Victor Harbor to Yankalilla?
what about the HKS GT-SS?? how do they match up to some of these other turbos?
https://www.sau.com.au/forums/topic/206230-hks-vs-trust/#findComment-3651408
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
    • To clarify what I posted above, I thought you both had a situation where it cancelled sooner one way than the other.....if it is reasonably even where it cancels in either direction that is probably normal (consider gentle movements like lane changes, you don't want it to need half a turn of lock to turn the indicators off)
