hey guys,
I was just wondering exactly how much engine oil do i need to put in my skyline. I have a RB25DET R33 using Ryco z145a filters... Does anyone know exact amount i need??
Cheers
Edited by br3ndan
Doesnt really matter, buy a 5L container of oil, put half of it in, run the engine for 10 secs, the check the oil. Once that is done, keep topping it up until it is on the full mark. Depends on how much oil is already in the engine as to how much it will accept. But roughly 4.4L would be the norm
THe problem is i filled it up and it was sitting a bit above the 3/4 mark. And itts been like that for awhile now. When i checked it today its gone over the full mark?
Any reason for this? THe oil is just under 5000kms old.
I put little bit less then 5 litres in. And at that time and other times it showed a bit over 3/4. And i did check it when the engine was hot.
Im using mobil 1 5w-50w....
Im pretty sure i put to much but i did start it up let the oil move to the filter and again top up... and it said 3/4 on the dip stick.
Maybe its the mobil 1 oil? to thin when i put it in?
Did you let the motor sit to let the oil settle back down to the normal level?
Also Ideally you'd probably want to run something closer to what Nissan recommends such as a 5W 30 instead of the thicker 5W 50 (the last number is the viscosity rating when hot, lower number = thinner)
What oil are you using? ..
I think i will change mine, but i got one more bottle left of mobil 1.. 5w - 50 w.
So ill use it up.
What do u mean let it settle down? After ive changed the oil or just normal checking of the oil ?
When you do an oil change you have to let it flow to the sump before you check the oil level. Same goes after the motor has been running. If you check it straight after switching the motor off it will be an innacurrate reading as the oil is still flowing back down to the sump from the head etc, so let it settle for a good 15 mins or so in those situations.
I use Royal Purple 5W 30, Nissan Recommends 7.5W 30
each to there own. Ive been running 5w50 mobile 1 in a car that does track work for over a year now and couldn't be happier.
as for oil amount. if your changing filter then as already stated its just shy of 4.5L. if your going to be doing track stuff then maybe chuck in about 500ml more.
Cheers
Camden
Cheers
Camden
Cheers mate. THanks for the info
I can just tell, threads gonna be about which oil is better. haha, my 2 cents....i use magnatec 10w30 and couldn't be happier...cus it's free!
nah we don't need to do that there are plently like them already :huh:
so if you ignore my "branding" earlier here is what i think is rough guide. Only get a fully synthetic, make sure the cold weight is between 5-10 so it gets things like the turbo lubed up nice and quick, and the hot weight really can vary from 30-50. I kind of go the thicker hot weight because these are old engines. my clock says 80,000 so in truth its prolly way over 100k so the internals are no doubt far from looking like they did 12 years ago. oh and finally make sure this happens every 5000km. Then everything in life will be just peachy ;)
also have you read the goods on oils sticky? think you might find it most helpful.
cheers
Camden
All done.
Took approx 4.5 litres. Mint R33 you were correct, last time when i filled it up i didnt wait for the oil to come down back into the sump. This time i did and its all good!
I ended up using mobil 1 5w-50w since i had one more bottle left. But i might start thinking about other oil at a later date. i.e closer to the next 5000k oil change.
Haha.. yeah about the goods on oil... its just a massively long topic about which oil everyone thinks is better. I was kinda after the oil capcity rather then what oil to use .
Thanks for all your help! Appreciated!
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
    • Are you doing the work yourself or are you paying for labour?
