Item:RB20det complete low km motor out of cefiro with cefiro crossmember (good for s13 conversion)
Age:1991 ceffy halfcut
Condition:in very very good condtion,complete motor with turbo very low kms all stock(no gear box)
Price:$1900 o.n.o
To Fit: (What car)R32,cefiro,s13
Contact:PM for mobile number if ur serious
Comments:(cefiro had 56K KM on the clock when chopped) great set up for a s13 rb conversion
(also have ECU and loom)
Price drop
will sell as short motor for $1450 minus crossmember,turbo,loom and ecu
or complete setup for $1800
Edited by streetcredit
PRICE DROP
WILL SELL THE RB20DET AS A SHORT MOTOR FOR $1350
THIS IS A LOW KM RB20DET CAME OUT OF A CEFIRO HALFCUT WITH 56K ON THE DASH CLUSTER (DASH CLUSTER HAS BEEN SOLD B4 PPL ASK
IM BASED IN ADELAIDE BUT CAN FREIGHT ANYWARE IN AUSTRALIA WITH MAINFREIGHT
CHEERS
what exactly does it come with??? computer/loom???
pm me asap with more info as im in Adelaide and could pick up asap.....
ADRIAN
PM SENT CHAMP
QUOTE(AdrianA @ 5 Mar 2008, 06:59 AM) *
ADRIAN
PM SENT CHAMP again
    • What could be causing my clutch problem besides a bad master or slave then? Both those parts are new
    • Just came across this, but in QLD I start leave again in 2 weeks, if it is still available I might drive up and check it out Unless, @MBS206 do you live near here????, if so I could hit you up with a finders fee https://www.gumtree.com.au/s-ad/hope-island/auto-body-parts/nc-mx5-factory-hard-top/1328976391
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
