i just saw the wood
and i think i vomited a little
actuall im trying to get , not the one in pic,,,ya its horrible, I shat man heheh lol, im trying to get the Brushed aluminium one, looks great in a black skyline I think, but im wanna know if they are any good, quality and etc....
Wouldnt it be cheaper doing it yourself? I think there's a thread (maybe in DIY) where people are painting their own for $30-40. I was thinking of doing the same thing, but not being any sort of paint expert I'd have no idea how to get a brushed metal look.
Im colour blind, will be a really bad job if I do it :) , so far I couldnt find that thread in DIY, still looking.
Thinking getting this brushed aluminium dash trim + plus black and silver sport steering wheel + silver gear knb and hand brake mmmmmmmmmmm yum yum :yes:
I think a chick who drives a 34 on here did it absolute shit... half the parts didnt work or fit correctly
Really......hmmmmmmm, how hard is to to paint it my self...? any special spray can for this perticular thingy? or any auto paint spray will do the job...hope removing the panels are not a bitch :)
Is it just contact or something or actual dash parts?
the silver part is about 3mm thick acrylic, and has 3m double sided tape on the back.
the best part is it doesnt scratch easy, like the factory coating.
    • Gday, Due to not finding much up to date info on this topic I thought I'd make a thread to get peoples latest opinions/recommendations. Background info -  I've got a S1.5 R33 GTST as a fun project car, mainly for street use and occasional drag strip, apart from all the cosmetic things I'll be doing a full rebuild of the engine with forged internals. Since it'll be getting new cams (kelford) and springs to match I thought I might as well get new lifters and valves while I'm at it, the dash says 160k KMs but the engine seems pretty tired, compression measures about 130psi across all cylinders so I'd like to freshen everything up. This is where I'm tempted to just fork out the extra and go solid lifters while it's all apart, aiming for 400-450kw atw with a flex tune. Assuming all supporting mods (oiling, fuel and all bolt ons) with a lightly ported head and turbo to match (yet to make a decision possibly gtx3582r or similar from Hypergear) I've seen the Tomei kits with just the buckets getting around, Supertech sells most things - Supertech High Performance Cam Followers | Trusted Racing Cam Followers Questions -  Has anyone found the Hydraulic lifters to limit them at this power level? Is it usually found that you can just clean the stock lifters and find they work fine?  Does going solid lifters save any headaches/issues with hydraulic lifters in the future? Any recommendations on other things that will need to be replaced, I know I'll need to get the solid profile cams but can you use the same type of valves and springs/retainers and is it recommended to change the guides and stem seals?    Summary -  Basically looking for pros/cons and wanna know if I'll actually need the extra RPMs from solid lifters or it'll just be bragging rights to say it ReVs OvEr 8000 Cheers
    • Ha ha ha, this stuff they had was installing Toshiba PLCs that were made some time in the 1990s, and they were replacing GEM80 PLCs. To let those two talk (staged upgrade along a ~1.2km long building that was split into 4 sections), was a bunch of WinXP machines running Java gateways... There was no way to put something like ProfiSafe in... Most of the HMI machines were WinXP, with Java program, with a custom button board emulating a keyboard... About the only buttons in the operator stations that went direct to the PLCs was the eStop. There was some interesting design stuff in that place...
    • Stock bypass valves are good for plenty of boost.
    • Check for fuel flow out of the outlet end of the rail. Check for spark. Try to start with aerostart (or pressure can brake cleaner or similar solvent in a car) prayed in through TB. If you have fuel and you have spark and it will fire on substitute fuel, then seriously suspect that E85 sitting for ages in your fuel system has destroyed something and put it in your injectors.
    • Nissan stock oil pressure is typically about 1 bar at 1000 rpm plus about 1 bar per thousand revs on top.
