removed everything down to the sound proofing muck on the floor, 4w steer long gone, all unused brackets bolts heat shields.
fuel tank when today and put a fuel cell in and that alone will be the best part of 15kg i think.
https://www.sau.com.au/forums/topic/206293-gtr-r32-weight/#findComment-3651256
if rules allow for it maybe remove the rad support and front and rear reinforcement bars and replace with chromolly tubing. also maybe start drilling holes in flat non structural body panels and dimple die'ing it.
https://www.sau.com.au/forums/topic/206293-gtr-r32-weight/#findComment-3651378
Yes that all long gone.
door windows winders motors etc are gone door trims too still need to take the hole saw to the door frames though.
I do have a substancial cage in the car though so there would be 30 odd kgs in that.
Looks like some gram light wheels and carbon fibre bonnet and boot are next
https://www.sau.com.au/forums/topic/206293-gtr-r32-weight/#findComment-3651852
a few other things you may or may not have taken out,
rear wiper and motor.
In mine I stripped back the entire wiring loom and removed all the excess wiring that is now not used. There was a substancial ammount of "free" weight there. You can halve the wiring under the dash easily.
ABS been removed and the assosiated wiring??
Running a full exhaust still or side pipe??
https://www.sau.com.au/forums/topic/206293-gtr-r32-weight/#findComment-3652135
There is not a great deal you can do without besides the ABS, air conditioning etc its more about saving weight.
Besides the obvious, you can strip the loom and rewire with the bare essentials. you'd be suprised how much wiring is unused once you remove the HICAS, ABS etc.
Single turbo conversions are lighter than typical twins.
Stick with alloy piping if possible.
Carbon canisters can be removed as well as the piping
Heater hoses and other water lines if you have stripped the inside out
Washer bottle and hoses.
Smaller battery
You can pretty much take anything out thats not needed if your building a circuit car.
https://www.sau.com.au/forums/topic/206293-gtr-r32-weight/#findComment-3652376
gee... i dont know how come ours is so heavy?
our car still weigh's 1380!
carbon boot
carbon doors
carbon airfilter box
no dash cluster
carbon panel and stack dash
one seat
no air conditioning
no abs
no hicas or pumps
nothing behind the dash
lexan door windows
no interior at all
some internal panels cut out
all bumper reinforcement gone
no rear wiper or motoboot and bonnet cathes gone
all boot hinge mechanism gone
most brackets gone
not sure how i could lose another 100 kilo, let alone 150!! :)
Edited by giant
https://www.sau.com.au/forums/topic/206293-gtr-r32-weight/#findComment-3652436
If its a track car then i think you would be silly to remove ABS.
Thats only my 2c...along with the fact that everbody seems to be obsessed with removing weight, which is fair enough. But no one ever seems to consider that you can do a hell of a lot with relocating where the weight is located. ie moving it lower in the car or into the cabin/centre of the car
https://www.sau.com.au/forums/topic/206293-gtr-r32-weight/#findComment-3652450
you have a pretty comprehensive cage in it though.
Mine only had a rear jap half when it was last weighed. besides the carbon pannels mine is as stripped as your car.
There is always the chance of errors on the scales behalf as well I guess (public weigh bridge in my last case)
https://www.sau.com.au/forums/topic/206293-gtr-r32-weight/#findComment-3652571
    • True, might get it looked at. Found out you can in fact flatten the 12v battery relatively easily too the other day (kids lefts the hazards on) so meaning to get that checked in the new year. What's odd is it'll blow cold from both vents if you have the ac down as low as poss (18), but anything else the passenger one blows warmish. Also has been summer since I got it obvs but noticed it didn't seem to want to blow hot last night when we had a cold snap.
    • You ask for things. You specifically state you want responsiveness. A link was provided for a far superior, more responsive option. Find a MX5 workshop that will install it for you. Maybe MX5 Mania will throw on the Fab9 kit. It seems they want to charge almost 14K installed for their kit, so if they charge you $6K to install the FAB9 kit then you'll be ahead? Though really, the 2.5 with a 2860 running low boost will more or less feel as good as anything else. It's a lot of displacement and a small turbo. Think of a more modern RB26 with one stock turbo :p TBH, truth be told I've been driving my own car, and use about 50% throttle at most for 99.9% of the time. Mr Bogan is likely similar so this is all going to be semantics for the use case he actually has. (He'll be happy with anything relative to now) However, the EFR is hands down far superior in this use case. You really, really, really, really do notice it over the Garrett or equivalent.
    • You are correct, the earlier the torque, the earlier things snap
    • Gents, it will be getting the MX5 Mania kit and the 2.5 will be staying where it is My query was about the 0.64 or the 0.86, whilst the 0.64 might spool a bit faster, would the 0.86 be better IRT EGT and mechanical sympathy, with only a small difference in spool And as I assume I won't need alot of boost to get to 200kw, probably around 10 psi, and with max rpm at 6500, would high EGT even really be a issue with a 0.64 I'm heading into MX5 Mania at the end of Jan to discuss the install, so any info is welcome prior to that Basically have a chat and book a time so they can throw on the turbo kit, and fit a oil cooler with a thermostat, drive in drive out of course  In other news: just finished cleaning the car inside and out, it's now all ready to get covered in bugs and dirt driving to Goulburn tomorrow to lunch,  and go for a stroll along woolondilly River with the daughter and her boy, and of course, visit my grandcats and my new grandpuppy
    • Sounds like it has an actual problem with mode select doors, or something.
