removed everything down to the sound proofing muck on the floor, 4w steer long gone, all unused brackets bolts heat shields.
fuel tank when today and put a fuel cell in and that alone will be the best part of 15kg i think.
https://www.sau.com.au/forums/topic/206293-gtr-r32-weight/#findComment-3651256
if rules allow for it maybe remove the rad support and front and rear reinforcement bars and replace with chromolly tubing. also maybe start drilling holes in flat non structural body panels and dimple die'ing it.
https://www.sau.com.au/forums/topic/206293-gtr-r32-weight/#findComment-3651378
Yes that all long gone.
door windows winders motors etc are gone door trims too still need to take the hole saw to the door frames though.
I do have a substancial cage in the car though so there would be 30 odd kgs in that.
Looks like some gram light wheels and carbon fibre bonnet and boot are next
https://www.sau.com.au/forums/topic/206293-gtr-r32-weight/#findComment-3651852
a few other things you may or may not have taken out,
rear wiper and motor.
In mine I stripped back the entire wiring loom and removed all the excess wiring that is now not used. There was a substancial ammount of "free" weight there. You can halve the wiring under the dash easily.
ABS been removed and the assosiated wiring??
Running a full exhaust still or side pipe??
https://www.sau.com.au/forums/topic/206293-gtr-r32-weight/#findComment-3652135
There is not a great deal you can do without besides the ABS, air conditioning etc its more about saving weight.
Besides the obvious, you can strip the loom and rewire with the bare essentials. you'd be suprised how much wiring is unused once you remove the HICAS, ABS etc.
Single turbo conversions are lighter than typical twins.
Stick with alloy piping if possible.
Carbon canisters can be removed as well as the piping
Heater hoses and other water lines if you have stripped the inside out
Washer bottle and hoses.
Smaller battery
You can pretty much take anything out thats not needed if your building a circuit car.
https://www.sau.com.au/forums/topic/206293-gtr-r32-weight/#findComment-3652376
gee... i dont know how come ours is so heavy?
our car still weigh's 1380!
carbon boot
carbon doors
carbon airfilter box
no dash cluster
carbon panel and stack dash
one seat
no air conditioning
no abs
no hicas or pumps
nothing behind the dash
lexan door windows
no interior at all
some internal panels cut out
all bumper reinforcement gone
no rear wiper or motoboot and bonnet cathes gone
all boot hinge mechanism gone
most brackets gone
not sure how i could lose another 100 kilo, let alone 150!! :)
Edited by giant
https://www.sau.com.au/forums/topic/206293-gtr-r32-weight/#findComment-3652436
If its a track car then i think you would be silly to remove ABS.
Thats only my 2c...along with the fact that everbody seems to be obsessed with removing weight, which is fair enough. But no one ever seems to consider that you can do a hell of a lot with relocating where the weight is located. ie moving it lower in the car or into the cabin/centre of the car
https://www.sau.com.au/forums/topic/206293-gtr-r32-weight/#findComment-3652450
you have a pretty comprehensive cage in it though.
Mine only had a rear jap half when it was last weighed. besides the carbon pannels mine is as stripped as your car.
There is always the chance of errors on the scales behalf as well I guess (public weigh bridge in my last case)
https://www.sau.com.au/forums/topic/206293-gtr-r32-weight/#findComment-3652571
    • Wives never seem to find things funny. Especially when they're trying to sleep, and you've found the new funniest thing ever. I've never seen someone be able to get try and be cranky with me, while they're holding back fits of laughter... 😛   Also, I tell mine it's payback anyway. She has BiPolar. So the household can get quite emotionally wild at times 😛
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
