im honestly not sure if they do or not.
Ive only ever used it to get an idea of what the car weighs.
I have the results from my old corner weight setting somewhere, might check it to see if the more recent weigh bridge was acurateish or not.
Obviously proper scales are always going to be more acurate.
Tacker how did you weigh yours??
jesus you've done well tacker and brad, ours is 1550 two up full of fuel :)
Our new car has done most of the stuff you mentioned so hopefully we will get down to about the same. if no rules rear parcel shelf and most of the boot floor is heavy as well as the tank. lots of weight in the doors and windows, hicas and abs. exhaust can be really heavy too.
1550! Mines definitly no where near that.
It does have the cage in it now though which could have added 50-60kg back into it.
duncan you have two seats as well dont you?? Ive only got one seat fixed to the floor.
Agree about the exhaust, mine was weighed with a side pipe and no mufflers. There can be 30Kgs in an exhaust if its got decent mufflers and mild steel.
two of everything certainly does not help.
Mine was last done with 50 litres and no driver. I only weigh 65Kgs so nothing drastic added really.
Are you going to part the wiring looms and strip all the unused wires out duncan?? I found its very worth while doing.
From memory I filled 3/4 of a garbage bin with wire and tape that was no longer being used. I have a photo of it all somewhere.
I ended up running a length of 7 core trailer wire to the back of the car to run the lights and then just the basics to opperate the ATTESSA. It literally halved the wiring to the back of the car. Also under the dash there is the massive loom that runs to the NS of the car. You can pretty much cut the whole thing off and run 10 wires to the ECU side of the car.
The loom that runs to the front of the car. I got rid of it and rewired the lights and nothing else. Again a length of 7 core did the job and more than halved the loom size easily.
Edited by Risking
Weighed my 32 at WSID.
Half a tank of fuel, 16's, everything in car like jack, spare tyre, full interior, stereo, front, rear strut braces etc,
1530KG without me.
Only pulled out rear Hicas rack and lines etc up to bellhousing area.
I did mine on a set of long acre corner scales maybe they were wrong i am not sure. it was done after our qualifying session and my mates EVO 7 came in at 1365kg
Side pipe is done but i done understand Russ how your car is heavier than mine scales must be wrong here i think.
gee... i dont know how come ours is so heavy?
our car still weigh's 1380!
carbon boot
carbon doors
carbon airfilter box
no dash cluster
carbon panel and stack dash
one seat
no air conditioning
no abs
no hicas or pumps
nothing behind the dash
lexan door windows
no interior at all
some internal panels cut out
all bumper reinforcement gone
no rear wiper or motoboot and bonnet cathes gone
all boot hinge mechanism gone
most brackets gone
not sure how i could lose another 100 kilo, let alone 150!! :banana:
Our GTR's are ~1280 kgs (no driver, minimum fuel), some things I don't see on your list, keeping in mind that we run full glass and standard panels;
Carbon fibre tailshaft = 8 kgs
Titanium exhaust = 23 ks
Wheels (17 x 9) and tyres (245/40/17) = 16 kgs
1989 & 1990 models are 35 kgs lighter than 1991 to 1994 models
One coat of paint, no undercoat = 5 kgs
Chrome molly cage = 18 kgs
Holinger gearbox = 14 kgs
Fabricated transfer case = 9 kgs
Poly bushes (no steel cases) = 3 kgs
Alloy flywheel & carbon clutch = 4 kgs
Alloy pedals = 2 kgs
Sound deadening = 12 kgs
Minimum wiring harness = 19 kgs
Plus about 50 or 60 items that weigh less than 400 grams each, but it all adds up
Cheers
Gary
sorry yeah i didnt put in a few other things
but yeah we have
carbon tailshaft,
4 foot side pipe
titon billet alloy pedals
no sound deadening
all alloy intake
we have added back very large brakes,10.5 inch rims & 285 rubber and full dry sump setup(prob 20 kilo)
we do run a clutch that would weigh atleast 10 kilo though.
im going to weigh mine again tommorrow to see what its at now with the cage done.
Besides pannels there is really nothing else that can come out of the car.
Tacker its well worth the effort to strip the looms. If you can take them right out and only run the wiring that you need to. Makes it easy when you start with a bare shell but can be done either way.
Grumble angry muttering
Wish i had not started this thread now!
Being an electrical engineer i hate wires and now you guys have told me i can get another 19 KGs out of the old shite heap if i cut most of it out.
More louder angry muttering
Not sure how u'd drop 19kg when I weighed my entire harness earlier at 15.5kg. I'm sure you could drop an easy 5kg from just cutting wires off you don't need, maybe 10kg if you did custom wiring from scratch.
Also, I have a 100% bare interior + engine bay shell with all removed parts sitting in the garage so if anybody needs something weighed...
Edited by benm
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
    • So I'm in the final stages of assembling my single turbo RB30/26 and had a question regarding MAP reference points.  I've seen several recommendations such as tapping the cylinder 2/3 ITB, tapping the intake manifold at cylinder 2/3, or using a point on IAC. First two are doable but require permanently modify part and the third is "out" as I plan to delete the IAC.  All that to say my question is can I used the "bleeder" in the center of the ballance tube as a MAP Reference? I'm running a catch can so I don't need it for the PCV system. My thought process is it "pulls" from all 6 cylinder, and it's between the ITB and the cylinders making it ideal for MAP reference according to what I can find. Thoughts?
