There is not a great deal you can do without besides the ABS, air conditioning etc its more about saving weight.
Besides the obvious, you can strip the loom and rewire with the bare essentials. you'd be suprised how much wiring is unused once you remove the HICAS, ABS etc.
Single turbo conversions are lighter than typical twins.
Stick with alloy piping if possible.
Carbon canisters can be removed as well as the piping
Heater hoses and other water lines if you have stripped the inside out
Washer bottle and hoses.
Smaller battery
You can pretty much take anything out thats not needed if your building a circuit car.
Guys,
when removing the carbon canister do you just block the outlets or do they need to be reconnected somewhere
chromolly is 1/3 the price. who has the weight figures of standard vs chromolly v cf?
concept. will await this reply!!
and would like to know about the carbon canister too. mines floating around somewhere in my engine bay hardly attached to anything
I don't get the rush for the c/f tailshaft unless you have too much money to spend.
Because I just want to be able to say to girls:
"Yes that's right ladies......... I have a carbon shaft. Form an orderly line to the left, and no pushing."
either way its still weight i want to get rid of as thats my main goal for now.
and on the plus side, single piece shaft rather than the current.
and barron, a light weight clutch/flywheel would be somewhere 5x (+++) the cost of the shaft correct?
No Angus i just put a 4.2 kg alloy flywheel on for 500$
http://www.vividracing.com/catalog/acpt-ca...r32-p-9406.html
Is there anywhere in australia that makes them? Or just US shops? I'd like one, but I doubt they're off the shelf items for my car.
hey, since my car has a r34 gearbox in a r32 i need an odd sized one also.
so get your length of your shaft right and i can forward on to him if your interested. as i've told him i need an odd sized one too.
$1400 !
Thats very good.
People spend more than that on making thier GTR look faggy.
A carbon tailshaft is well worth the money. Manufacturers are using them now on fairly cheap sports cars for the range of benifits they offer.
I've got this on my list of mods for my R32 GTR bunky and I'm only building a 300rwkw car.
any chance one of you guys know how much a bare and empty r32 gtr fuel tank weighs ?
Titanium exhaust = 23 ks
but surely you can get lighter exhausts? i've got a 3" zorst that weighs 12kgs ( not inlcuding cat, front pipe, dump pipe)
Edited by Dan_J
he was saying 23kgs is the amount of weight saved. most titanium systems would be under 6kg.
oh ok thanks for clearing that up
at a guess i would say a bare gtr fuel tank is 12 to 14 kg.
you wouldnt have a spare one that u cud just wack on sum scales to double check? :laugh:
    • I've uploaded logs / the current map to Gdrive if anyone has any ideas. https://drive.google.com/drive/folders/1FPnr22Z-EilG7tYdHSi0Qb07P2jfFLKV?usp=sharing
    • I'm running a Haltech Platinum Pro with the stock map for the RB20DET + tweaks for my build. When I started it this morning, the IAT was at 32F/0C (Outside temp was ~42F) and the AFRs went off the scale for my AEM gauge. I let it run for ~30 seconds then turned it off. I then did a smoke test, by hooking into a vacuum line directly behind the throttle body, and confirmed there was no leaks ( i let the smoke tester run for ~5 minutes / confirmed it was generating smoke before hand ). I then started the car again, after fixing a power steering leak.... and it seemed to be happy for ~30 seconds (was at ~11/12), but then seemingly shot back up to ~18 again. I then let the car run for a few minutes, thinking this was just cold start related, but the AFRs never came back down. I didn't let the car fully warm up, so maybe this makes sense, but I'm not sure what to do? The AFRs, when I last ran it, were normal, but because of personal reasons I haven't been able to break in the car. It was rebuilt last year. Engine / Mod list: Supertec pistons Spool rods Kelford 270 cams and Springs Stock crank Deatschwerks 900cc injectors Walbro 255 (Wired directly to the battery relocated in the trunk) NKG Audi R8 Coil packs + Conversion Harnesses from Wiring Specialties Holset HY35 turbo Haltech Platinum Pro ECU Haltech boost controller (wired in for high boost RB25 Neo transmission + needed bits for the speedo to work
    • Not great at getting the camera out fast enough for cars driving. Even in traffic. S15 is in front of the kei truck.
