im honestly not sure if they do or not.
Ive only ever used it to get an idea of what the car weighs.
I have the results from my old corner weight setting somewhere, might check it to see if the more recent weigh bridge was acurateish or not.
Obviously proper scales are always going to be more acurate.
Tacker how did you weigh yours??
jesus you've done well tacker and brad, ours is 1550 two up full of fuel :)
Our new car has done most of the stuff you mentioned so hopefully we will get down to about the same. if no rules rear parcel shelf and most of the boot floor is heavy as well as the tank. lots of weight in the doors and windows, hicas and abs. exhaust can be really heavy too.
1550! Mines definitly no where near that.
It does have the cage in it now though which could have added 50-60kg back into it.
duncan you have two seats as well dont you?? Ive only got one seat fixed to the floor.
Agree about the exhaust, mine was weighed with a side pipe and no mufflers. There can be 30Kgs in an exhaust if its got decent mufflers and mild steel.
two of everything certainly does not help.
Mine was last done with 50 litres and no driver. I only weigh 65Kgs so nothing drastic added really.
Are you going to part the wiring looms and strip all the unused wires out duncan?? I found its very worth while doing.
From memory I filled 3/4 of a garbage bin with wire and tape that was no longer being used. I have a photo of it all somewhere.
I ended up running a length of 7 core trailer wire to the back of the car to run the lights and then just the basics to opperate the ATTESSA. It literally halved the wiring to the back of the car. Also under the dash there is the massive loom that runs to the NS of the car. You can pretty much cut the whole thing off and run 10 wires to the ECU side of the car.
The loom that runs to the front of the car. I got rid of it and rewired the lights and nothing else. Again a length of 7 core did the job and more than halved the loom size easily.
Edited by Risking
Weighed my 32 at WSID.
Half a tank of fuel, 16's, everything in car like jack, spare tyre, full interior, stereo, front, rear strut braces etc,
1530KG without me.
Only pulled out rear Hicas rack and lines etc up to bellhousing area.
I did mine on a set of long acre corner scales maybe they were wrong i am not sure. it was done after our qualifying session and my mates EVO 7 came in at 1365kg
Side pipe is done but i done understand Russ how your car is heavier than mine scales must be wrong here i think.
gee... i dont know how come ours is so heavy?
our car still weigh's 1380!
carbon boot
carbon doors
carbon airfilter box
no dash cluster
carbon panel and stack dash
one seat
no air conditioning
no abs
no hicas or pumps
nothing behind the dash
lexan door windows
no interior at all
some internal panels cut out
all bumper reinforcement gone
no rear wiper or motoboot and bonnet cathes gone
all boot hinge mechanism gone
most brackets gone
not sure how i could lose another 100 kilo, let alone 150!! :banana:
Our GTR's are ~1280 kgs (no driver, minimum fuel), some things I don't see on your list, keeping in mind that we run full glass and standard panels;
Carbon fibre tailshaft = 8 kgs
Titanium exhaust = 23 ks
Wheels (17 x 9) and tyres (245/40/17) = 16 kgs
1989 & 1990 models are 35 kgs lighter than 1991 to 1994 models
One coat of paint, no undercoat = 5 kgs
Chrome molly cage = 18 kgs
Holinger gearbox = 14 kgs
Fabricated transfer case = 9 kgs
Poly bushes (no steel cases) = 3 kgs
Alloy flywheel & carbon clutch = 4 kgs
Alloy pedals = 2 kgs
Sound deadening = 12 kgs
Minimum wiring harness = 19 kgs
Plus about 50 or 60 items that weigh less than 400 grams each, but it all adds up
Cheers
Gary
sorry yeah i didnt put in a few other things
but yeah we have
carbon tailshaft,
4 foot side pipe
titon billet alloy pedals
no sound deadening
all alloy intake
we have added back very large brakes,10.5 inch rims & 285 rubber and full dry sump setup(prob 20 kilo)
we do run a clutch that would weigh atleast 10 kilo though.
im going to weigh mine again tommorrow to see what its at now with the cage done.
Besides pannels there is really nothing else that can come out of the car.
Tacker its well worth the effort to strip the looms. If you can take them right out and only run the wiring that you need to. Makes it easy when you start with a bare shell but can be done either way.
Grumble angry muttering
Wish i had not started this thread now!
Being an electrical engineer i hate wires and now you guys have told me i can get another 19 KGs out of the old shite heap if i cut most of it out.
More louder angry muttering
Not sure how u'd drop 19kg when I weighed my entire harness earlier at 15.5kg. I'm sure you could drop an easy 5kg from just cutting wires off you don't need, maybe 10kg if you did custom wiring from scratch.
Also, I have a 100% bare interior + engine bay shell with all removed parts sitting in the garage so if anybody needs something weighed...
Edited by benm
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
