All my looms weighed 23kgs including a few relays, factory fuse boxes, junctions etc etc.
Ive taken basicly all of that out and put in a very basic engine loom (haltech) and a few lengths of 7 core trailer cable weighing 5Kgs maximum. I also put the entire thing in factory looking condute from super cheap just for apperance sake.
Yeah no problem at all duncan. Pm me what your planning and when you want to do it.
Ok fellas, you've removed so much sh*t from your 32 GTRs that i think you're approaching the practical limits.
Modding every single car component in some way really leaves little left to do, apart from perhaps a carbon monocoque.
I bet you'd be using 'lightweight motor oil' if you could!
Edited by R338OY
any chance i could get a dvd copy too! i would fix you up for it! :)
consider it done at nil cost.
Im getting Stace to do the covers for the DVD's too, so they will be nice and proffesional.
may look at bootleging them on here and making a small donation to SAU with a percentage of the proceeds.
chris
evo looks fantastic with the wide body kit too!!
i see Squeeky been sending some quiet pic's here and there by the sound of it LOL. I think it will be on HI octane web site soon. We had some issues with the gearbox on the weekend so it didnt show its true form, look out when it does.
My entire wiring harness weighs 15.5kg
Clarification 1, that incudes relays, fuse boxes, all the brackets, clips, nuts, washers and bolts that hold them in.
Clarification 2, the 19 kgs is a net reduction, we took out around 25 kgs and added about 6 kgs
Improved Production regs don't allow the "easy" weight reductions (eg; CF bonnet, boot, doors etc). So we have to use what ever freedoms are allowed to their max, for example clutches are "free" hence the use of a 7" quad plate carbon clutch with alloy flywheel and dissengagement hydraulics costing around $10K.
Cheers
Gary
Whats the fuel tank worth?
and an average weight of a 50L cell for the boot?
i'm getting bored at home and the cars telling me it wants to go on a diet. tho i'm probably going to remove alot more.
a 5kg titanium exhaust will be on its way.
removing all the 4ws pumps and lines unless, there is something the lines are good for.
might get a wholesaw onto the bar reos
i still have A/c too. but thinking of keeping it for them hot track days where i'll be the coolest guy out :(
Edited by Angus Smart
removing the fuel tank only to fit a 50L fuel cell seems a bit out there. unless you are planning some enduros? 30 or 40l maybe, but if it's a street car just leave the fuel tank where it is. if it's a track only car then fit a 20 or 30L. no point doing half measure. then all you get is not much weight saved on track, and much more inconvenience on street.
haha
i've seen someone use a chisel before and didnt like that. took him a long time and lots of swearing.'
as for heatgun, that would make for much stickyness. tho might be used in combo with ice too..
ice. sounds nice and hard should work ok i think..
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
