im about to fit a lexan passengers window and remove the drivers (will use a net instead) You have to retain a glass windscreen for saftey in most events.
By the time you remove the glass, motor, regulator and wiring assosiated with it there can be decent savings per door.
Ive also removed all the old steel lines this week and replaced with alluminium/ speed flow fittings.
The steel ones are really not that heavy but the alloy is lighter and its fresh.
Andrew whilst you not using that headlight can I borrow it and make a mould? I want to make a carbon item but cant find a decent one to mould it from.
yeah no worries!
i wouldnt mind having a peek at that dry sump you have there.
not long now till the motor is here!
No worries, next time you have a free weekend come past home an check it out.
The whole engine is sitting out atm so its pretty easy to see how its all been set-up prior to being fitted to the car.
Im still working the small bugs out that I ran into on a spare engine before fitting into the car for the last time.
Biggest problem im having is the actualy sump pan and scavneger.
Aaron was telling me about the engine you have coming over, sounds like you found a half decent buy with it, well done.
If you want to offload the old donk let me know, may be interested as a 2nd spare.
Edited by Risking
All we did for the lexan windows was use a strap buttoned to the window from the inside and then velcro it to the roll cage to keep it tight, only downside to this is trying to put some tension(from the outside) on them when transporting the car. otherwise it works well.
Yeah i'll come over some time this week if thats good!
this is what i picked up Apparently a 34 N1 motor that was possibly rebuilt, and put into a 32 bought, then smashed after 3000km of ownership.
Edited by Angus Smart
yer but skyline windows are hard to fit due to a frameless door and they have to be made out of 5mm material and are thermo formed to get correct curve.
easy to form them just put in boiling water for a few minutes then clamp it to the original glass to cool. would be 15 or more kgs in weight saving from all glass being replaced
from all glass?
i removed the front windscreen from the r32 shell and its 10 kgs,i'd say rear windscreen would be 10kgs or more.
so if the plastic weighs 1-2 kgs each replacement, you cud end up saving 18-16kgs from just the front+rear windscreens alone
how much do door windows weigh? (i dont have a spare one)
i have seen r32 gtr in option videos weight 1000-1100kg cool.gif i see if i can find which one it is in and upload it
if ya do www.megaupload.com
Edited by Dan_J
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
