Removing Stickers
Any JDM performance shop can install them. Literally a sensor, 4x fittings (if that) and off you go. Wiring is 3x wires to your aftermarket ECU. Sensor GND, +12V (not +5V), and sensor output. -
By Watermouse · Posted
I got a Fenix for my LS1 VZ Commo last yr and it was a perfect fit and I liked the quality of it. -
Can you help! Can you tell me a few places you got your Flex Fuel Kits installed in Sydney The only one I know of is Tunehouse. Thanks in advance!!!
Yea my thought was tighter engine when hot is more load a poor ground connection can't take. On that note, I had time to check my driveshaft verical alignment tonight, it's +2 and -2 at either end, so thats perfect and how I had set it up last year. What would be the easiest way to check horizontal alignment between my diff and transmission? I can think of a few ways but they're all complicated and I feel like I'm overthinking it. I'm hoping it's that as I can't see any other reason why I have developed driveline vibration since I put the motor back in.
