Hi guys
Just a question.. my car's got the 4WDTURBO and TOYOTA badges on it for quite a while.. i guess it was there since it was built.. I removed the badges but the residue is taking a very VERY hard time to get it out.. I tried the NO MORE GOO orange oil and it didnt help.. i tried eucalyptus oil and it doesnt help.. does anyone have any ideas?
Cheers
Bernard
https://www.sau.com.au/forums/topic/206312-removing-badges/
Hi guys
Cheers
Bernard
terpentine or spirit and its gone
https://www.sau.com.au/forums/topic/206312-removing-badges/#findComment-3650613
when i took my tail lights off, i got some of that goo that holds them in on the rear bumper, i used turpentine to get it off but it did fade the paint quit a bit :D
hey sam how ya been? :(
:) yeh thats what im worried.. the paint on the celica is really good and i dont wanna spoil it.. :(
any other suggestions guys/gals?
cheers
Bernard
https://www.sau.com.au/forums/topic/206312-removing-badges/#findComment-3650759
hmm.. so i should try to use a hair dryer and heat up the gunk for a few minutes then try to rub it again with the eucalyptus oil?
im just rubbing it with a piece of cloth with eucalyptus oil.. is that right?
Cheers
Bernard
https://www.sau.com.au/forums/topic/206312-removing-badges/#findComment-3650970
hey mate try and use some critus spray i used it to take off my badges 18 yrs old came off like a charm get it from super cheap read the label
hope it helps
alright ill try that out cheers for that mate
https://www.sau.com.au/forums/topic/206312-removing-badges/#findComment-3651262
Don't use a rag.... use a paint brush and keep the turps on the glue, as runs down just keep brushing it back up.... be patient, time is your friend here. When the glue is soft, get a soft piece of plastic, (so that you don't scratch the paint) and scrape it off, it should roll up like a load of snot, wipe it off on paper (kitchen towel works really well) and repeat this process until it is all off. Use a rag last, to clean up any residue. If you use a rag 1st, you will have to rub hard. This is what generally "fades" the paint, the rubbing, not the turps. If the area looks brighter after, use a paint renovator on the surrounding area, to match it up. The paint under the badge will usually be in better condition than (the sun damaged paint) that's around it. This may not be the case if your car is just in from Japan. The sun is many times less harsh there.
Good luck
https://www.sau.com.au/forums/topic/206312-removing-badges/#findComment-3655089
I had to take some badges from a Toyota recently and found that the glue had actually eaten into the paint. I ended up having to sand with some 1200 then buff it up. I also recently took some stickers off the side of a tarago and the same deal but the glue had eaten into the paint so much it had to be resprayed.
https://www.sau.com.au/forums/topic/206312-removing-badges/#findComment-3655293
wow.. hmm.. i didnt really understand that appealing.. could u sort of maybe list it out in orders like 1,2,3? :teehee: im really scared of using turp.. coz the paints in really great condition.. BUT... heck the car is 18 years old :sweat:
https://www.sau.com.au/forums/topic/206312-removing-badges/#findComment-3655624
wow.. hmm.. i didnt really understand that appealing.. could u sort of maybe list it out in orders like 1,2,3? :) im really scared of using turp.. coz the paints in really great condition.. BUT... heck the car is 18 years old :)
1. Turps should not damage paint. It is a very slow solvent. Meths, thinners etc will damage paint. Other slow solvents that can be tried are kerosene, and diesel, (but I know that they don't work as well.
2. If you use a rag, you will smear the glue as it softens, you also use far more turps. The idea here is to use the solvent (turps) to soften the glue. This only happens while it is in contact with it. Which is why rags are useless.
3. Find a smallish paint brush (10mm is fine) and "paint" the turps onto the glue. It will run down, so use the brush to keep moving it back up.
4. After some time, (usually 2-5 mins) you will find that the glue has softened. Use a soft piece of plastic to get rid of the glue, softer plastic is best as it is less likely to scratch the paint. Lift and scrape the softened glue from the surface, then dispose of it. Sometimes only the top layer will have softened and you may have to repeat parts 3 & 4 several times.
5. When all of the glue is off, then use a rag with turps on it, to get rid of any residue.
6. If required polish the area to match up the rest of the paint.
7. The only paint that is going to be affected by turps is enamel. Do a test patch 1st, somewhere inconspicuous with a rag and see if you get any colour on the rag. If your car is in original paint, I doubt that it has any enamel on it. It is hardly used anymore. Enamel usually goes powdery in the first couple of years.
By the way, I run a sign business in Coogee. I have done lots of badge removal, this way. It works well. If there is still some foam (sponge) from the badge on the car even better as it hold the turps there, right where you need it.
If you still have doubts, PM me, I'll give you my phone number, you can come around and I'll have a look and help you. It's all pretty easy really. :O
John
Edited by Appealing
https://www.sau.com.au/forums/topic/206312-removing-badges/#findComment-3655987
If you still have doubts, PM me, I'll give you my phone number, you can come around and I'll have a look and help you. It's all pretty easy really. :)
John
Thanks alot john im gonna give it a try this evening :) will let you know how it goes
Cheers
Bernard
https://www.sau.com.au/forums/topic/206312-removing-badges/#findComment-3656355
    • I recently got their dbw 74mm throttle body and pedal kit. It is sensational quality especially the wiring harnesses. Unfortunately I can’t answer u about the fitment to stock inlet manifold as I’m going Rahjab Racing forward plenum. Only one thing to be careful of is understand u have to pay gst and import fees if your purchase is over $1,000 in one shipment.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
