I've got a set of coilovers and the ride is really stiff with the damper setting on the softest.
The front isn't overly stiff (the weight of the motor helps a little) but the rear skips over bumps. Gets annoying on crappy roads.
The rears are 17x9 inch with 235/45 rubber on. I checked this forum and saw this rim is ideal with 255 wide rubber. Will wider tyres give more flex and soften the ride up? Or is a 50-55 profile necessary?
Cheers
https://www.sau.com.au/forums/topic/206313-stiff-ride/
Your spring rates are probably the main cause of the stiff ride...What make are the coilovers?
You do not change tyre profile to soften your ride...it will only throw your overall diameter and speedo out...unless you plan on going back to 16s or 15s with a 50 or 55 profile.
https://www.sau.com.au/forums/topic/206313-stiff-ride/#findComment-3650679
Thanks for the speedo warning :(
They're Nismo, and i'm 95% sure are S-tune.
So keep 45 profile OK. If i went up to 18's i'd go 40 profile yeah?
Will getting a wider tyre help the ride at all, or just grip? As they sit, the 235's are too small and aren't flush with the rim.
Can i change spring rates and to avoid changing coilovers? My mate reckons these are drift spec coils (came on the car when imported)
Also: when i push on the car (i.e. on the boot) there is sh!t all flex from the suspension and the tyre.
Edited by R338OY
https://www.sau.com.au/forums/topic/206313-stiff-ride/#findComment-3650686
This thread shows you how to measure your springs so that I can work out the spring rates for you
http://www.skylinesaustralia.com/forums/Sp...Are-t79157.html
Once we know what the spring rates are then we can make soem suggestions.
The next thing for you to check is how low is the ride height. Centre of wheel to guard it should be no lower than 350 mm front and 340 mm rear. Ride comfort and handling suffer if it is any lower than that.
Cheers
Gary
https://www.sau.com.au/forums/topic/206313-stiff-ride/#findComment-3653086
    • Can't see that being a thing.
    • My fob has never worked, I once attempted to follow the procedure to re-key it, (I have other fobs for the car alarm thing in there). I actually have three of them. Do aftermarket alarms take over the pairing mechanism for central locking? Or do they piggyback off it? I suppose it depends on the system, right? I have four sets of keys/keyfobs. One definitely works, one I think works, one definitely doesn't work, and I have the OEM one that has never worked :p. Is this fixable/workable/whatever? I mean I know it's beyond "just clean it" but how *do* they get synced up?
    • It's actually a really weird comparison... the MX5 is on another level and I kinda question this comparison at all. It'd be closer to compare it to a GTI/Golf/Hatch anything that kicks around. NC MX5 with a turbo has the right to go up with and beat the FD RX7 or 180SX or any other JDM hero car. That's the comparison that would really ruffle feathers.
    • @MBS206 you need more shed in your life... What sort of car is your mates race car?  Hopefully he returns the favour when you're ready to get cracking on yours! None of my mates are into cars so I don't have to worry about that as a distraction thankfully.  I have enough other distractions so I don't need that one too!  Between working 6 days a week (5 1/2 really so 55 hours or so per week), both kids have basketball almost every week night (including Friday night in Melbourne - 2 hours away), my daughter plays netball as well, my sons footy has started now and I coach his under 14's side as well as I'm on the Footy club committee this year, I ride motorbikes every spare Sunday I can find, plus trying to be some sort of a husband.  Life is a busy little exercise at the moment!  I wish there were 8 or 9 days in a week sometimes!
    • Ha ha, that is very true!  I'm too scared to leave it in the position though, it tingles my balls seeing it like that!
