Make:nissan skyline R34 GTT
Model:R34 GTT
Milage:83000 kms
Transmission:5 speed manual
Colour:red
Complied?yes
RWC supplied?yes
Currently registered?yes
Price:20000
Contact:Bob 0422358205 or email [email protected]
Comments / Modifications:all stock i am first owner lowered nismo factory exhaust
Images:at carsales.com.au type rego ugb168 all deatil in there
Edited by bobby09
  • 2 months later...
  • 2 years later...
hey mate, if ur interested in swapping i have a vk group 3 repllica, very clean car, worked 308 engine probly done less than 15000kms, very clean engine, i have car listed on here to look at, have a look and let me no, cheers, 0421175527
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
