Make: NISSAN
Model: R32 GTS4
Milage: 62k
Transmission: R32 GTR 5 speed gear box
Colour: custom gun metal grey w/ a gold pearl
Complied? YES
RWC supplied? No
Currently registered? Rego'd in QLD until July 08.
Price: 12.9k
Contact: Michael on 0414 398 019 (anytime)
Comments / Modifications:
PROJECT VIDEO: CLICK HERE
Ok guys, Up for sale is my beautiful missus that i have spent all of my money on over the past year. In its previous form i only got 6 drives out of it!!! It of course back then was an RB20 powered 32. thousands and thousands of dollars later it is now almost complete and already up for grabs! :(
It's currently sitting at turbo tune getting the last of the wiring finished so will be ready for its first start up and tune in the next couple of weeks :D
Reason for the project was on my 6th drive of this car it blew up... shortly after buying it last year from a guy in Queensland. Diagnosed it was just a blown head gasket, but workshops wanted approx 1.5k to fix it. So as ya do, i said screw that ill just buy a RB25det for that price and put it in, then it will all be sweet............. sadly thats not how it turned out. :(
I located a very good condition series 2 rb25det sitting in a '96 model stagea front cut with only 62k on the digital cluster. completely bog standard. I sold the standard rb25 turbo with intention to use my GT2540R from my previous rb20 set up. later down the track we found in the blow, bits of spark plug had completely destroyed the rear wheel of the turbine. so that was replaced with a brand spanking new GT2871R turbo with bigger housings from garret. RB20 plenum had to go (dont fit on rb25's), and that was replaced with a brand new Greddy style front feed plenum with a new 80mm throttle body. anyway, i could go on for pages and pages worth of mod stories but ill just list what it has for easier inspection...
RB25DET s2
RB20det GTS4 sump and front diff (shorter ratios than the GTR)
Shimmed rear diff
GTR gear box
NISMO short shifter
NISMO extra heavy duty twin plate clutch (plenty of meat left)
NISMO Flywheel
GTR forged wheels
GTR front bar
recon springs and shocks
BRAND NEW GT2871R (440hp turbo) sourced from ATS
reconditioned S15 480cc injectors.
BRAND NEW just jap radiator
Malpassi 1.7:1 rate fuel pressure regulator
Haltech 3 coil waste spark ignition.
MSD DIS4 CDI ignition using 3 channels, 2 step RPM limiter for anti-lag/launch control.
BRAND NEW Greddy style intake plenum
BRAND NEW 80mm throttle body
Stainless exhaust manifold with GT25 flange welded on.
HKS super dragger exhuast (no cat)
Custom dump
Turbosmart 38mm Street gate, external wastegate.
Screamer pipe
4WD/2WD switch and loom (choose between 2WD or AWD at the flick of a switch)
Haltech external boost control solenoid.
Turbosmart V-port BOV.
Modified standard fuel rail
RB20det Remapped ECU by SPEEDLAB
Full flow oil system and oil filter relocator
Front mounted Oil cooler
DRIFT oil catch can
DRIFT pod filter with custom made intake pipe
Bosch 040 700hp in tank fuel pump.
600x300x75 front mount intercooler.
Various after market Guages
O2 sensor digital guage
Greddy turbo timer
Images:
some pics....
Edited by zertek
seen the heart break with this thing. unfortunately micky is set to lose a friggin shit load of money from her but thems the breaks with cars
good luck with sale, should be easy sale seeing as paint job is almost worth half of wat your asking for the car
ANOTHER mod for u mike
Paint less than 12 months old
well it only needs to go through cop shop to pass. so it will just involve putting on stock turbo and exhaust for a day. cop shop is heeeeaps more lenient than regency and aslong as all the engine numbers match and pass (i have receipt for the rb25 and still have the origional rb20) and nothing too obvious is sticking out then it will be fine. other than the top mount, nothing else really other than the turbo timer and 2 guages will have to be hidden/removed.
hey buddy real nice car...i also have a gts4 and was thinking i should buy an rb25det from a stagea and put it in mine..just wondering how difficult is it and is there anything i need to look out for..oh and also did the stagea s2 come with the neo engine???
cheers mate and once again thats a real nice car :P
vinnie
vinnie
hey mate, no need. just buy mine :)
Na i got the rb25det from a stagea series 1, but they come with a series 2 rb25. the series 2 stagea come with the NEO. really all ya need to do is swap the front diff ratios to rb20 so all 3 of your diff ratio's match.
hey for all who are worried about buying the car and coz the plates are regoed in qld and a scared they will have to take it to regency or cop shop.all u have to do is rego the car on the net. i brought my car in qld 2 years ago and i regerested it on the net so ive got my adress on the car from adelaide but still got my queensland plates on it..
its the easy way to miss regency.
car is tuned and running. drove it home yesterday. went for a REALLY conservative tune on 15psi and it easily pumped out 255kw at wheels. sorta come to a swap deal with my mate for a bunch of parts. but if anyone is willing to take it this week at the asked price, then my mate told me to just do that instead.
    • I mean it's probably likely that people overestimate their skills in dialling in a setup and noticing the changes. I had SK shocks and springs, and added heavier springs and got them revalved by Sydney Shocks to suit based upon what I told them I wanted the car to handle like. I got back a completely different feeling set of shocks, which probably (?) feel great on track but holy hell are they rough on tram tracks and the like. The shock dyno actually looks pretty similar to Shockworks (from what I can surmise from a screenshot of a youtube video - and my dyno printout...) Truth be told I doubt I'd be any faster or slower with either setup, or camber/castor combination. I also had whiteline eccentric castor bushes up front of my R34. I removed them and put in poly non-adjustable ones to soothe my OCD (nobody ever set the castor the same side to side, and it'd be near impossible to do) and be happy the wheel is centered in the well now for clearance reasons. Yes I wanted it to move 1mm 'back' :p I've effectively set my castor back to stock, negating all the benefits of that which is supposedly massive. I've probably also altered toe and camber in a negative (detrimental) way. I can't tell any difference steering the car.
    • You reckon? I have to disagree. Notwithstanding that at some point we may all be forced to do this to our cars if we want to keep driving them, there is absolutely nothing about an electric-converted-previously-IC-car that is ever good. EVs that are built by OEMs on platforms that were originally IC already suck, let alone the shitty outcomes that result from doing it as a retro to something that was actually built as an IC car. This is because the platform really needs to be designed to house the battery in a useful place (ie, down as low as possible) and the motors are properly located relative to the wheels that they have to drive. Converted platforms already suck at this. But when you try to shove sufficient battery capacity into a previously IC car, you can't put it down on/in the floor, because that space doesn't exist. You can't find enough space where the fuel tank used to be (if it is an inboard fuel tank) and you don't want to hang it out behind the rear axle line if you had a rear fuel tank. And there's not enough space in the tunnel if you still want to use it for anything remotely like what it was originally used for. The engine bay is too big for a motor, and you'd really prefer that the motor for the rear wheels wasn't in the front engine bay anyway. And there's not enough room where the diff was for a proper man-sized E motor. And then.... there is the complete lack of soul and emotion that is provided by EVs. There are some cracking restomods out there. Like the Alfaholics GTA thingo. But it is petrol powered. Look at the alternative EV version of a GTA restomod by Totem. it is jaw droppingly beautiful. But by all reports is is objectively awful to drive, despite having 600 HP or something, simply because there is nothing there. It sounds like a sewing machine or a leaf blower. It should scream and wail and make the hairs on your neck stand up. Oh, and it's 1500 bloody kg in a car that was <900kg when new. GTRs are heavy enough as it is without pushing them up to 2tonnes worth of pork.
    • https://www.dezeen.com/2025/01/06/nissan-electric-r32-skyline-gt-r-godzilla-sports-car/   I reckon this is pretty cool. Lots of other Resto mods have turned to ev power.
    • hahaha @joshuaho96 the most action it gets is when I have to drive from West to SE VIC to meet the fam. Even then, it;s on highway cruising speeds
    • don't know anyone in this thread, but i just found it, read the entire thing in a few hours, realized greg is still posting progress, and just have to say, this is awesome. it looks awesome. 100% right about the Uras kit making it a pain to get on hoists...have the same kit on my 34 and it takes six 2x4s and race ramps to do it without taking parts off. this reminds me exactly of this thread. https://grassrootsmotorsports.com/forum/build-projects-and-project-cars/r63-amg-the-unicorn-of-my-destruction/110824/page8/
