there is a r33 gtst track car in england obviously not the same but very similar, only kind of really serious gtst/gtt model track i have seen, cannot remember its name for the life of me though. It was pulling close to 550 horse, running a motec with the dash, so you can imagine how much it would have cost. All depends on your budget if your minted then the skies the limit.
If it were stripped already with CAMS approved cage, Id put it back together with only parts I needed so its on a nice diet, nice and light.
Also maybe looking at replacing some windows with lexan?
single seat
some nice power mods, Id say 250rwkw would keep me happy - so any turbo upgrade + supporting mods.
Brake upgrade with ducting (larger rotors, braided lines, pads, could even go brake bias if you were real serious)
suspension and driveline upgrades (clutch, diff, springs, shocks, caster, camber, sway bars etc)
then light wheels (with some nice gaps for air flow) and semi slicks
If you want a bit of an idea - check out Russ's (giant's) R34 build up - sure its a GTR but you can follow similar ideas :ermm:
Get ready for big bucks and a mission.
But if you plan it out it'll be an awesome project. Hmmm sounds like fun too :ermm:
boosted Rb26 300rwkw with strong supporting mods--> lots of suspension, braking and drivetrain work. Top notch tyres.
And plenty left over too.
22" chromies
Neon Lights
doof doof
...................................................oh wait....wrong spec
suspension, brakes and tyres.....with it stripped out, you'd have a much better power to weight ratio even with the stock engine
Honestly? It would have to be very cheap.
The R34 GTT is basically as heavy as an R32 GTR, so if you are going to build a track car you are getting the weight of the GTR but the penalty of only beign a rwd platform.
Best bet is go rwd and get an R32/33 which will weigh in nice and light...or go with an R32 GTR and live with the weight only have the traction afforded by AWD
You mean the Apex Performance/K sport r33?
The one in this video
Search "k sport r33" on youtube for tons more vids, seems to go pretty well :D
  Roy said:
...the penalty of only beign a rwd platform.
Penalty schmenalty... evil_weevil has the right idea.
Get a reliable car with enough power to make the chassis have a think and it is done.
An R34 GTT weight 1440kg std, whats an R32? 1280, and an S13? My point is the rwd Skyline and Silvia platform can be made to be a real quick car with some very basic mods and do not require huge power.
An R34 GTT is getting up in the scales and will in turn need more power, more tyre, more brakes etc etc you are looking at the GTR end of the spectrum of spend to get the same sort of lap speed
  Laurence said:
Hehehe there you go chasing plastic trophies again... what you need to do is chase the plastic trophy inside your heart. :)
Chick, chick--> BOOM!
Lol. Ok you want it done cheap? No problem. Just go for basics, but do it quality.
230-250rwkw (plenty), supporting mods (duh), HD clutch + light flywheel, lowered on adjustable coilovers, 17x9 inch rims at the rear sitting on 255/40 rubber (even more= better), front 17x8/9 inch. Sway bars and strut braces. Oil cooler. Think about a GTR rear wing (do 34 ones swap to a gtt?). Also uprate the brake pads, fluid and get braided lines. Get as much weight off as possible, esp. on the front end (hard on a budget though).
Test that out and go from there adding whatever it needs. Now that i think of it, this isn't really that cheap...
Have fun! Oh, and picsorban when the project starts ;)
Edited by R338OY
Step 1 - Find out category you want to enter
Step 2 - Work out the class in that category that suits the car most
Step 3 - Build car to category rules
Step 4 - Buy tyres, petrol, parts
Step 5 - Enter events
Step 6 - Repeat Steps 4-6
You don't need a CAMS cage to screw around on track days (unless that has changed since I left Oz) so building the car for sprints or to some imaginary ideal spec is not a good idea. You may find that a car that runs such narrow wheels stock is not able to run 9" rears as R338OY suggested, categories have very strange rules that mean you often have to do weird things, so don't go out buying wheels or GT-R wings before you know you can use them.
Guys like Roy know a lot about these sort of rules so his advice is very useful.
Personally I would stick an RB25DET in it, stock brakes (which Sydneykid says are fine), big radiator, big oil cooler, some gauges, a seat and a GT-R front bar, BN Sports bonnet and a stock GT-R spoiler with some extension to raise it up a bit. Then the widest wheels I could fit under the arches with the narrowest recommended tyre size then lower it lots so the roll centres are wrong (just to annoy people).
Edited by Laurence
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 馃槈. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 馃槏.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 馃檹 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 馃槈. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 馃槏 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
