there is a r33 gtst track car in england obviously not the same but very similar, only kind of really serious gtst/gtt model track i have seen, cannot remember its name for the life of me though. It was pulling close to 550 horse, running a motec with the dash, so you can imagine how much it would have cost. All depends on your budget if your minted then the skies the limit.
If it were stripped already with CAMS approved cage, Id put it back together with only parts I needed so its on a nice diet, nice and light.
Also maybe looking at replacing some windows with lexan?
single seat
some nice power mods, Id say 250rwkw would keep me happy - so any turbo upgrade + supporting mods.
Brake upgrade with ducting (larger rotors, braided lines, pads, could even go brake bias if you were real serious)
suspension and driveline upgrades (clutch, diff, springs, shocks, caster, camber, sway bars etc)
then light wheels (with some nice gaps for air flow) and semi slicks
If you want a bit of an idea - check out Russ's (giant's) R34 build up - sure its a GTR but you can follow similar ideas :ermm:
Get ready for big bucks and a mission.
But if you plan it out it'll be an awesome project. Hmmm sounds like fun too :ermm:
boosted Rb26 300rwkw with strong supporting mods--> lots of suspension, braking and drivetrain work. Top notch tyres.
And plenty left over too.
22" chromies
Neon Lights
doof doof
...................................................oh wait....wrong spec
suspension, brakes and tyres.....with it stripped out, you'd have a much better power to weight ratio even with the stock engine
Honestly? It would have to be very cheap.
The R34 GTT is basically as heavy as an R32 GTR, so if you are going to build a track car you are getting the weight of the GTR but the penalty of only beign a rwd platform.
Best bet is go rwd and get an R32/33 which will weigh in nice and light...or go with an R32 GTR and live with the weight only have the traction afforded by AWD
You mean the Apex Performance/K sport r33?
The one in this video
Search "k sport r33" on youtube for tons more vids, seems to go pretty well :D
An R34 GTT weight 1440kg std, whats an R32? 1280, and an S13? My point is the rwd Skyline and Silvia platform can be made to be a real quick car with some very basic mods and do not require huge power.
An R34 GTT is getting up in the scales and will in turn need more power, more tyre, more brakes etc etc you are looking at the GTR end of the spectrum of spend to get the same sort of lap speed
Hehehe there you go chasing plastic trophies again... what you need to do is chase the plastic trophy inside your heart. :)
Chick, chick--> BOOM!
Lol. Ok you want it done cheap? No problem. Just go for basics, but do it quality.
230-250rwkw (plenty), supporting mods (duh), HD clutch + light flywheel, lowered on adjustable coilovers, 17x9 inch rims at the rear sitting on 255/40 rubber (even more= better), front 17x8/9 inch. Sway bars and strut braces. Oil cooler. Think about a GTR rear wing (do 34 ones swap to a gtt?). Also uprate the brake pads, fluid and get braided lines. Get as much weight off as possible, esp. on the front end (hard on a budget though).
Test that out and go from there adding whatever it needs. Now that i think of it, this isn't really that cheap...
Have fun! Oh, and picsorban when the project starts ;)
Edited by R338OY
Step 1 - Find out category you want to enter
Step 2 - Work out the class in that category that suits the car most
Step 3 - Build car to category rules
Step 4 - Buy tyres, petrol, parts
Step 5 - Enter events
Step 6 - Repeat Steps 4-6
You don't need a CAMS cage to screw around on track days (unless that has changed since I left Oz) so building the car for sprints or to some imaginary ideal spec is not a good idea. You may find that a car that runs such narrow wheels stock is not able to run 9" rears as R338OY suggested, categories have very strange rules that mean you often have to do weird things, so don't go out buying wheels or GT-R wings before you know you can use them.
Guys like Roy know a lot about these sort of rules so his advice is very useful.
Personally I would stick an RB25DET in it, stock brakes (which Sydneykid says are fine), big radiator, big oil cooler, some gauges, a seat and a GT-R front bar, BN Sports bonnet and a stock GT-R spoiler with some extension to raise it up a bit. Then the widest wheels I could fit under the arches with the narrowest recommended tyre size then lower it lots so the roll centres are wrong (just to annoy people).
Edited by Laurence
    • Yeah, the latter. No diff should have a centre replaced without checking clearances because its unlikely to be the same as whatever came out. Not that that stops most people just checking a new centre in
    • Major thread necro but how bad of a job is it to DIY? Looking at it online it looks like if you reuse your ring and pinion as long as those are in good condition it should be fine to just pull the axles/front cover and replace the diff that way? Or should I be replacing everything and doing preload measurements/gear mesh testing like the factory service manual mentions for the rear diff?
    • in my list I had the R33 GTR as the best Skyline. Infact I had all GTR's (33>34=32), the NSX, the GTO, the 300ZX, the 180SX, the S15 better than the FD RX7. I had the MR2 and the A80 as 'just' better. I also think the DC5R Integra looks better but this is an 01 onwards car. I also think the FC>FD. It's almost like aesthetics are individual! The elements @GTSBoy likes about the FD and dislikes about the 180 are inverse in my eyes. I hate the rear end of the FD and it's weird tail lights that are bulbous and remind me of early hyundai excels. They are not striking, nor iconic, nor retro cool. The GTO has supercar proportions. I maintain these look much better in person (like the NSX) especially with nice wheels and suspension which is mandatory for all cars pretty much. Some (or all) of these you have to see in person to appreciate. You can't write a car off until you see one in the flesh IMO. Like most people we probably just like/dislike cars which represent certain eras of design or design styles in general. I also think the 60's Jag E type looks HORRIBLE, literally disgusting, and the 2000GT is nothing to write home about. FWIW I don't think the Dodge Viper Gen1's have aged very well either. You can probably see where I rate bubbly coupes like the FD. I know we're straying now but the C4 and C5 absolutely murder the Viper in the looks department as time goes on, for my eyes. Wouldn't surprise me if people who love the FD, also love the MX5, Dodge Viper, Jag E Type, etc etc.
    • I used to hate R31s, and any of the other Nissans that led up to it, and any of the Toyotas with similar styling, because of the boxiness. They were, and remain, childish, simplistic, and generally awful. I appreciate R31s a lot more now, but only the JDM 2 door. The ADM 4 door (and any other 4 door, even if they are unique compared to our local one) can eat a bowl of dicks. The Aussie R31 is also forever tarnished by their association with stereotypical bong clutching Aussie R31 owners of the 90s and early 2000s. I think the Nissans of the 70s (other than 120Y/180B/200B) are far superior looking to the 80s cars. The 240K era Skylines are boss. The same is broadly true of Toyotas. Hondas don't ever register in my thinking, from any era. Mitsus are all horrid shitboxen in any era, and so also don't register. Subarus are always awful, ditto. Daihatsus and Suzukis also don't generally register. They are all invisible. I think the SW20 MR2 looks fiddly. The 3000GT/GTO is like that but way worse. Too many silly plastic barnacles and fiddly gimmicks ruined what could have been a really nice base shape. Kinda-sorta looks like a big heavy ST165 Celica coupe (and I'm not sure if that's a good thing or a bad thing). I think the 180SX is dreadfully bland. It's not bad looking. But it has no excitement to it at all. It's just a liftback coupe thing with no interest in its lines, and bad graphical elements (ie wide expanses of taillight plastic on the rear garnish). The S13 Silvia is a little better - getting closer to R32 shapes. But still....bland. S14? Nope. Don't love it. S15...a little better. Probably a lot better, actually. Benefits from not being like a shrunk in the wash R34 (where the S13 was a shrunk in the wash R32 and the S14 looked like a Pulsar or something else from the stable on Nissan mid 90s horrors). The Z32 was hot as f**k when it came out but hasn't aged as well as the A80. Keep in mind that I think the R33 is the most disgusting looking thing - and out of all the previous cars mentioned is objectively closest to my precious R32. It's just....real bad, almost everywhere you look. And that is down to the majority of what was designed in the 90s being shit. All Nissans from that era look like shit. Most other brands ditto. In that context, the FD absolutely stands out as being by far the best looking car, for reasons already discussed. Going behind the aesthetics, the suspension alone makes it better than almost any other car.
    • If they just called it the "Mazda Tiffany", it would have been spot on.
