hi
i have done searches regarding this but can not get a definitive answer.
i have an rb25 with a forward facing plenum which was designed to be used with a xf throttle body.
i know they open up differently to rb25 ones.
so i need to know which TPS i need to use. i have heard that you can use an rb30 one and modify it or an sr20 but cant find any concrete info on which is easiest.
if the sr20 one fits without modification id prefer to go that way but if not and i need to go for the rb30 one well ill deal with that as it comes. if you need to use the rb30 one is there a wiring diagram that shows exactly what needs to be changed? and are the rb30 n/a and turbo ones the same?
thanks
https://www.sau.com.au/forums/topic/206345-xf-throttle-body/
taken from;
http://paulr33.skylinesaustralia.com/docs/...powerfc-faq.htm
Ford Falcon XF Throttle body with the PowerFC
Some owners upgrade the standard Skyline GTST single throttle body to a larger unit. A common donor for this part is the Ford Falcon XF Throttle body. The problem with this swap is the throttle body opens backwards on the XF unit so the TPS signal wont match. You need to use the Nissan RB30 TPS sensor which is the same as the standard skyline one and works with the XF unit.
A discussion thread on this topic can be found at: http://www.skylinesaustralia.com/forums/in...howtopic=151259
  • 8 months later...
  • 6 months later...
WHY RB30 TPS ??!? Why cant the standard XF TPS that came with the XF throttlebody be used ???
FORD XF TPS PINOUT :
GREEN - SIGNAL
ORANGE - 5V
BLACK - EARTH
They both operate at 5 volts so why cant the ford unit be wired into the standard RB25DET harness ?
I know the series 1 and series 2 RB25DET TPS are different as the series 1 has one plug and the series 2 has two plugs -
REFER TO:
http://forums.nicoclub.com/zerothread/283142
This forum listing explains how a 3-wire 5 volt TPS can be wired into the series 2 RB25DET (2-plug) harness
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
