damn that looks good.
but most cars do look awesome when lowered,with huge rims and a kit....
not practicle imo.
i think 18+ '' rims would fill it out nice but lowering it would spoil the ride
luxury wise it looks the deal.how many interior colours are avaliable?
not practicle imo.
For rims 20's look the best when you go more then that it looks like an over rimmed 300C, the 3 litre version actually fits 18's factory and you have to lower it a little but not as much as my V35, I have a set of CPV35 18's so I might fit them till my R35 GTR rims are sorted.
At the pits this morning while doing the paperwork up they first wrote it down as a Mercedes and when I told him it was a Nissan he was quite surprised, he said he could swear it was a Merc.
Trim wise is the usual tan or black like the V35 bit is full leather or full cloth Specs.
put up the pics with the v35 rims :teehee: the 16'' stock rims are really starting to get to me.. I'd like to know what the difference in ride would be with 20''s..
for those that dont know.. the Infiniti Q45 which sold in the US until 06 is a cut down version of the Cima..
An awesome site to check out some quick stats is get.to/q45
enjoy!
Pricing is slowly coming down to make 2001 and 2002 more affordable which is why I also want to comply them this year even though it is a limited market.
Chris I got the iPod all hooked up via audio and video lines in the car and blue tooth hands free hooked up fine, it is the 5th Cima the guys have done.
Jeff's Cima is a base model as he changes everything so a waste of money buying a mint VIP and he also has leather kits for them.
    • Hmmm, what do you mean by getting weaker? And where did you get that test done? I've been wondering about my battery because the cold starts crank super slowly. The voltage is fine. Not sure if cranking amps can be checked at home. Battery is 4+ years old.
    • No. The simplest wastegate hookup, with no solenoid or other form of "boost control" (ie, control over your boost control, if you know what I mean) is a single hose, direct from the turbo outlet/hot pipe, straight and only to the wastegate actuator. It is that pressure signal that drives the wastegate to open, providing the boost control (and by "boost control" here, I mean, limiting how high it can go, which is essentially the spring pressure of the actuator). You only end up with tee pieces and alternate flow paths once you start adding things to the boost control system to allow you to determine how much of that boost signal makes it to the actuator. There are so many ways to do that that there is no single way to run the hoses and tees and the like. If you have a stock boost solenoid, then all it does is either allow all the boost signal to go to the actuator, or open up to allow some of it to bleed off. There needs to be a restriction in that bleeder to allow only a small amount to bleed off. And in a stock system, that would then be plumbed back to the turbo inlet (for "emissions control" reasons). That is actually what that nipple on your BOV return pipe could/would be for. If you have an aftermarket boost controller and solenoid, then the above is mostly true, but there is no need for a restrictor in the bleed, because the solenoid is pulse width modulated to create a variable bleed off. The air that escapes from the bleed can either be vented, or also returned to the turbo inlet. For emissions reasons it should be returned to inlet, but the amount of air being vented is so small that it really doesn't matter (either from an emissions perspective, or from an air-fuel ratio affecting perspective).
    • And other times you just need to go buy bigger injectors?
    • Yup. I actually just blew my turbo. LOL.  should have checked this thread before today. i also have no boost solenoid. so it should be...one line from wastegate to turbo inlet, and a T somewhere in that line that connects to the wastegate return pipe?
    • It's recommended, however I can assure you a good amount of people don't bother. FWIW, the OEM battery lasted 4.5 years and I changed it prematurely too, I reckon could have stretched it to 5 years.
