Selling my track built GTR as i havent the time for it anymore.
mods are as follows
CRUX aero bonnet
8 points dash roll bar
Driver seat; RECARO full bucket seta
Meter; NISMO Full scale speed
Water T, Oil T, Oil P Exhaust T fuel P boost, knock meters
CS quick shift
Alumi buttery case
Fuel pump; NISMO
Fuel pipe; Replaced.
Oil P HICAS; Removed.
Rear member bush alumi spacer
Bush, Mount ; NISMO strengthen
APEX height adjustment
CUSCO adjustable rear upper arm
NISMO rear lower arm
MIDORI front upper arm
CUSCO tension rod
Front Brembo F40 Calliper (340 rotor)
ENDLESS CCM Brake pad
One off front alumi diffuser
RAYS TE37 (33R size) 17's
BRIDGESTONE RE 540S
CUSCO MZ Rear 1 way LSD
One off oil catch tank
DoLuck side tank radiator
EARLS 24 steps oil cooler
NISMO oil element block
TRUST Feul pipe
PAXTON filter x 2
PAXTON fuel regulator
BHS 150 ball bearing (Single full turbine)
Stain pipe exhaust manifold
AUDI racing Inconel westgate
One off front pipe
FGK super R muffler
HKS EVC2
ARS Blow off valve
SPARCO Alumi 3 layer radiator
HKS Piping
Strengthen hose and T bolt cramp
HKS Timing pulley
MOTEC M4 EMC
HKS front, rear tower bar
OS triple clutch
33R brake master cylinder
Engine mods:
Piston; TRUST 87.5 pi (Upper; SAURUS)
Cam; TRUST 264/264 9.1/9.1
Cylinder head; 0.2 mm polished.
Cylinder; Fake H boring and horning for O/S
Crank shaft; 33 WPC processed.
Conrod; Standard. JUN strengthen bolt
Head G/K; TRUST metal 1.1 mm
Valve guide; HKS Standard short cut processed
Valve spring; TRUST Strengthen spring
Valve timing; TRUST Slide pulley 103 degree/108 degree - 65 degree
Compression ratio; Around 8.7
Port, Firing chamber; Adjustment, Burr
Injector; Rochester 1000 cc
Fuel regulator; PAXTON
Delivery; TRUST
Fuel filter; PAXTON
Fuel pump; NISMO PAXTON. Strengthen. + intank twin.
Air cleaner; K&N TRUST
Inter cooler; PHM. SPARCO Racing 115 mm
Intake pipe; HKS Alumi
Turbine; GARRETT TO4S modified
Oil cooler; EARLS NISMO 34 steps EW condenser front mount #12 fitting. Oil element block.
Front pipe; PHM 80-85-90 pi Ulster one off. No CAT
Muffler; APEX Super R stain 90 pi modified.
EVC; Standard PCMV CTRL (Setting = 1.4)
Oil pump; Standard 33N1
Water pump; Standard 33N1 R32GTSt small pulley + belt
Oil pan; TRUST Baffle, sensor boss weld.
Catch tank; PHM Alumi one off
Computer; MOTEC M4/FI/ADV/LOG Turned
Water T, Oil T, Oil P, Fuel P, Boost, Exhaust T meters; HKS. (Oil P; TURST) 60 pi. Warning, Peak hold , Memory.
Speed meter; NISMO 320 km
F Brake pad; ENDLESS CCM
R Brake pad; ENDLESS CCM
F Caliper; BREMBO F40
F Rotor; BREMBO Slit 340 mm
R Rotor; Standard N1 rotor
Rear diff; CUSCO 1 way Initial torque 11 k
Shock; APEX N1-R
Sus; F Kei office. R APEX. F Direct 12K/60/200. R Direct 10K/65/225
Tension rod; CUSCO Pillow ball
Tire; BS POTENZA RE540S-S 255/40ZR17
Wheel; RAYS TE37 9J-17+15
Car is uncomplied but compliable. asking 21K without complience. located in vic pm me if u have any questions or 0408 57 86 27
Edited by nuR.spec
https://www.sau.com.au/forums/topic/206362-modified-r32-gtr/
  • 4 weeks later...
