2008 Fg Falcon Revealed
Flynnn
 Share
  • Replies 115
Posted Images
oh no big man i found that very offensive cause you think i look like you :banana:
yeh but my 13 year old japanese CAP looks and performs 10x better than your 2008 "refined" (cant stop laughing at that) falcon, thats hang on wait for it... built/desinged by a bunch of diploma engineers that rock up to work half pissed :D
but what would i know right...
What a f**ken riot !!!
I bet she is billy hairy all over her chest.
Can anyone say, VE door handles? Looks like ford went to Holden and brought them.
Ford Australia wanted to implement the falcon into the Ford global architecture so certain pattern cues were carried over from European Ford DNA , what they call it the " kinetic " design.
So the door handles are in fact the ones like on the Mondeo and not the VE.
Edited by Barbarian
Ahh finally the "Fairmont" turbo. I heard about these some time ago during a meeting with the state bosses here
From what i have been told the calder test days for the F6 have gone great, going to be much better around the track than the current ones
The model range looks great, finally a dash that doesn't look like its come from a cheap korean taxi
Orian....Aurion. You cant get 0-100km/h and 0-400m times out of power and torque figures. Look at the current GT, has 290kw and only does mid 14's if that.
actually in one of motor magazines tests they got the gt to do a high 13.
This one may be the pick of the range. Traditionally the Fairmont was the car for pensioners. But with a turbo motor Ford won't be able to go too soft. So you get the best motor they make in a reasonably well specced car without all the boy racer bullsh!t. Nice. Hope they price it well.
New XR6T looks like it'll get family car duties for me when me and the mrs settle down!
Sounds like a great car/package and looks pretty good, I think in the flesh would look better!
assyrian4evaa - you sir, need to open your eyes. You are as bad as the one minded bogans who bag out jap cars.
You obviously are not a car enthusiast.
well i guess you can get them on LPG from factory so that is their answer for that for now. and they are making them run leaner to get better economy, which is also why the power is increasing. i think it will all depend on what happens with the price of fuel in the future, and with ethanol.
u dont understand i am very open minded when it comes to cars atleast so dont just judge me from those few comments maybe if you heard about them as much as i have you'd be over them by now..
i like aussie cars and own 1myself but they just dont do it for me as much. i hope they sell really well because it keeps jobs around but we'll see how they go
 Share
    • I picked up an open Center with shafts. I was told the Open shafts will fit a mechanical LSD and looking at them. I think they will work. Will update
    • The manual says a lot about the different ratios requiring different shafts. all the Centers are the same but depending on the ratio, this determines the shafts because different ratios need the center to be offset more or less or right to left.
    • those 2 sets of shafts will not interchange and if you’re lucky you haven’t damaged anything with all your pressing and bashing you said you’ve done
    • Freshly built stroked RB25/28. Motor runs great but consumes a lot more oil then It should. This summer with the heat I was consuming roughly a quart per 1800-2000kms. Now with the cold weather coming in, I'm consuming a quart per 1000kms which is no bueno. I had originally chalked this out to break in taking a little longer then it should, but I'm now around 4000km's on this engine. I think it's fair to say something isn't quite right. Here's the kicker, can't find what's causing it. I've also spoken to my engine builder and Precision Turbo and can't figure it out. Here's my train of thought on possible causes and what I've done.  Precision Turbo - I originally started thinking my oil pressure might be a tad too high for my 6466 Gen2. I took the center cartridge out, and while yes there's signs of oil on the turbine heatshield, it's very moderate. There's also very minor in/out play that concerns me. I sent pictures and videos to precision and they said the residue and in/out play is minimal and they doubt this is the issue. For piece of mind, I went ahead and installed a Turbosmart OPR V2 to bring oil pressure down. Made no difference. Precision is willing to take it in on RMA for an inspection and I'll probably take them up on that offer for peace of mind. BTW. Is it just me or does the turbines inducer's look clipped and not even between each other? I just noticed this now while posting and looking at the picture zoomed in. Might just be the picture...  Rings - Hot compression test and leak down test look good. Compression is 160 +-2psi across the board. I leak down at 16% on cyl 1,2,3,5,6 and 18% on cyl4. Keep in mind I have a snap on leak down tester and they read high (I.E, 15% on my wifes 2018 Sentra with 70000kms). Sparkplugs show minimal oil (Only #4 seems to have a tad). At a quart per 1000km's though, I would be expecting them to be wet. Here's the kicker, I run WMI. I'm thinking what if my compression rings are great, but I have an oil control ring issue on cyl4 and my WMI is steam cleaning the pistons and sparkplugs? I can still see the "Spool" logo on top of my CP pistons. The only time I see smoke out of the exhaust is in the high rpm/load range. So far, this is my main culprit. I'll probably turn off my WMI and go out with the car at spring pressure tomorrow and repull the plugs. Other thing that's strange though is that I have never seen any oil in my catch can. Thing is still dry after 4000kms. Cyl1 - Left, Cyl6 - Right. Valve seals - They're new and I would expect oil consumption on idle, first cold start or during decel. None of which is happening.  Crankcase pressure - I have 2x 10an valve cover lines to a vented catch can. Head drain and opened up internal oil drain paths. I also don't run E85. I've never seen any oil in my catch can. Doubtful this is causing any issues.  Rear main seal - I have no visible leaks, but figured maybe it was my rear main seal. After now having added 2-3 quarts, I would expect oil to leak out the bottom drain channel and/or my clutch to be slipping.  Let me know your thoughts. With winter coming and taking the car off the road until spring, I'm fine with pulling the motor apart but I would hate to take it all apart and the turbo was the issue in the end.
    • Actually, the best option is probably to get some of the stronger aftermarket driveshafts that have both the 5x1 and 3x2 pattern on them, so OP can do whatever the hell OP likes with the diff in the future and not have all this angst. I posted a link to them sometime in the last 2 weeks, I'm sure.
